There the maintenance guys, supervisor and manager were stumped. Today one of them called me at home to tell me that the back two speakers on the rear shelf were "coaxial," making them "2 speakers" each. They appear to be ordinary speakers in appearance on the outside and from underneath them (looking from the trunk).
Can anyone tell me if this guy is blowing smoke and are there supposed to be speakers in the rear doors, or can they legitimately label those 6 speakers as "8 speakers" if 2 of them are "coaxial?" Thanks, Tom
Bruce
Pat
I would appreciate the opinions from the experts here. Is this a sign of misbanlance or/and misalgnment or problems of suspension parts ? I have not done any balance or alignment so far.
Also, I did all the service at Toyota dealer which I bought the car from. If I need a alignment job, what are the best shop? I heard from Sienna problem forum that Toyota may not be the best for this kind of job and they tends to charge more.
These are Good Year Integrity tires and have run 22k miles. If the 4 tires wear evenly, I would expect another 20k miles since I am no a aggressive driver. If the uneven wear is not solved, should I change the tires earlier? What is the best all season passenger car tire with good wet traction, decent handling and relative long life?
Thank you in advance for the advice.
Sha
Pat
Sha
I recently purchased a new 2000 Camry LE V6 a
couple of weeks ago. I now have about 200 miles on it. So far I've noticed that while driving, the steering wheel seems to be slightly off centered. 99% of the time the steering wheel is turned slightly to the right while driving on a straight level road. The car also feels that it drifts to the left the few times I've taken it onto the freeway going up to 55mph. Do I have an alignment problem? Is everyone else's steering wheel horizontal when they are going straight. This is somewhat annoying. Is it maybe the awful General tires that are on the car?
Secondly, does your rearview mirror vibrate when
you have the radio on or a CD playing? Whenever I look in the rearview mirror and the radio is
playing, everything in the mirror is a blur due to
the vibration. But I must say, the radio sounds
awsome. If this is a sacrifice I have to make for a good sounding radio, then I am happy.
Other than the alignment issue, this is a nice
car!
George
1) Have you experienced a continued misalignment problem?
2) Have your tires been rotated or replaced with a continuation of the problem?
3) Do you continue to have uneven tire wear and a drift either to the right or left?
4) Do you have vibrations in your auto, esp. above 50 MPH?
5) Have you replaced rear brake drums or other brake components prematurely?
6) Have you had any oil contamination and/or sludge in the engine?
Please share your experiences here and on the Sienna site as well. I'd like to look for trends in these autos.
cblake@erols.com
Now, we find that the front window motors are shot and will cost about a thousand to replace. We really checked out this particular year's model and were assured that it was very dependable.
Question - we're retired and in our 70s, really need a car that we can depend on. Are we likely to get more costly problems? And is the window motor thing unusual?
Good luck, that does indeed sound like a nightmare.
Pat
When you go through arbitration, do your homework and present your case well. Document everything: work orders, invoices, information from NHTSA sites on complaints, TSB, etc.
I got rid of my lemon 1998 Camry using my state's arbitration and wish you luck for doing so (or for getting it repaired, however, knowing Toyota Motor Sales and Toyota dealers, I would not hold my breath, if I were you).
article on fuel filters. They say change them,
cause "most GM filters" are "close to plugging
up", and they also say the slow clogging of fuel
filters puts a load on the fuel pump. They say the
"never change" recommendations of some
manufacturers are improper. My Camry manual has no recommended fuel filter
change frequency. My Toyota dealer refused to change the filter at 60,000 miles ( I was ready to pay). One established Toyota website says never change them.
Whats your experience? - do you have a Toyota, over 90k miles with the
original fuel filter? Tell me about it.
Also have you personally changed a Camry 4 cyl
filter? How hard? - Motor Service last year said
it was easy to screw it up and damage the pipe to the tank costing big bucks. A local repair shop told me the same thing - they say the end of the fuel line and the fitting on the filter itself are
strange and easily damaged (this may be why the dealer won't change it - but you would think Toyota would have fixed that long ago. Motor service did say to use only OEM filters.
I know it's not the CD because it is happening with a variety of different CDs that I put in the radio!
Don't the CD players in cars have a memory to prevent this?
Thanks in advance.
George
The only thing that I notice now is sometimes the car sort of stalls a little from initial takeoff in drive, although this doesn't happen all the time.
Thirty days ago, 150 miles from home, the engine simply quit running and required a new igniter and coil. That fix lasted for about a week when the same problem occurred only thirty miles from home requiring a new igniter, coil, distributor cap, plugs, and plug wires. Two days ago it happened again at cruising speed on the Interstate about 130 miles from home. This is getting expensive and no clear path to a permanent fix seems clear.
Has anyone had similar experiences with this problem? If so, was there a workable solution? The car as a whole is in good shape, no oil consumption and no other electrical/electronic malfunctions.
when the heat was on. I also noticed that the
climate control doesn't seem to operate properly.
When I try to use the climate control to increase
the temperature, the module only alows me to direct the warm air flow toward the floor. An attempt to redirect the air flow up or up and down simultaneously results in the AUTO climate control to dissengage itself. Also when trying to redirect the flow upwards, there is a noise comming from the left hand side (near the fuse box??). It sounds like a singing inductor or relay or something like that. It definately sounds like an electrical problem.
I will schedule a time with the dealer today. The car now has 43k on it but it's less than a year old. Do you think that this problem will be covered by my warantee? I hope so because it sounds expensive.
By the way, after almost FOUR months, someone came to inspect my leather seat on the driver side and concluded that it should be replaced for free. The seats are cracking along the creases in the leather and they will definately rip through the leather soon. They said about a week and a half ago that they'd call me when they've got the part and that it should take about 5 to 7 days..it's been MORE than that so far and no word...I'm gonna call them today and find out what's the deal.
Joseph
I want to disable it or fix it.
The only real problem it has is that it has a lot of trouble starting up after it warms up. If I hold the key until it starts it often takes say 3 seconds (estimating), or if I try once to start it then try again immediately it starts right up usualy. Could this be a fuel pump???
Also after it warms up it idles roughly. When it is cold and the air conditioner kicks in it automaticaly idles up and stays smooth. But once it warms up a bit and the a/c kicks in it dosen't idle up and runs very roughly.
And last but not least when taking off from a stop the peddle seems heavy and I realy have to push down and the engine must rev high (4000 aprox) to get it moving.
Should I get the engine tuned up and posibly a new fuel pump?
Tracy
1) Recently I noticed that the hand break light in the dash would not go off even with the break off. Now it stays on always. I really don't want to pay some ridiculous ammount at the dealer for getting this fixed. Does anyone know if I could easily do this myself? What could it be?
2) Also, I noticed in the front right side of the car, particularly when driving on smooth roads, a regular rythmic rubbing type sound causing a slight vibration in the car and the steering wheel. Could my tire be faulty? I had them replaced 15K ago and the allignment has been right on since then.
Any help is appreciated. Thanks.
Hope this helps. Post what you find out.
Can someone tell me what tire pressure I should have for my 2000 Toyota Camry? I looked at the label near the doorframe of the driver's door, and it states 29psi, and for the maximum vehicle capacity -which I assume means the weight of the cargo, it is 32psi for the maximum capacity of 900lbs? Does this mean that I should have the tires at 29psi, and only if I have 5 passengers - a full load (near 900lbs) - that I should add air and make them 32 psi? Or does it mean that the tire pressure can vary, that it can be between 29 and 32 psi no matter how heavy the cargo I am carrying, so that the maximum capacity stated is not related to the cargo weight, but instead it is related the the maximum capacity of the tire. This is very confusing. Please help.
Thanks in advance.
George
Usually when a car maker specifies light load and full-load pressures, the light load is only for 1-3 occupants and no luggage. Anything beyond that and you should go with the full load pressure.
Personally, in your case, I'd just go with 32 all the time; the lower pressure just provides a slightly softer ride.
Also, vehicle has recently developed prominant clicking/knocking/rattling noise from front suspension (sounds like both sides)only noticed when slowly going over speed bumps or other large irregularaties. First sounded like "loose" wheel trim rings (hubcaps), but noise is still present when trim rings are removed.
Anyone have similar experiences, and if so, what was the resolution?
Absolutely love the comfort, ride and power of this car, but these reliability issues are troubling. Expected to get 200k trouble-free miles with meticulous maintenance, but now I'm concerned.
