Have you recently switched from a gas-powered vehicle to an EV, or vice-versa? A national TV broadcast network would like to speak with you; please reach out to [email protected] by 12/5 for more details.
Are you a current or prospective Tesla customer who is having a change of heart about the brand? A national news reporter would like to speak with you; please reach out to [email protected] by 12/5 for more details.
2010 buick lacrosse Air Conditioning
2blbogey2blbogey Member Posts: 1
edited September 2017 in Buick
my lacrosse is indicating the outside air temp is -40f. the ac wont turn on. only the heater. what could be causing this?
Answers
  • kyfdxkyfdx Moderator Posts: 211,864
    A bad temperature sensor?
  • thecardoc3thecardoc3 Member Posts: 5,572
    -40f is the default temperature for an open ambient temperature sensor circuit. The sensor is on the bumper cover on the left front corner if the car. There is a grill section below the bumper between the fog lights. The sensor is located on the drivers corner of that part of the bumper. With the sensor unplugged, there should be a 5v signal on the dark green/white wire and ground on the yellow. With the sensor connected normal operating voltage will range from about 1.5v to 4v depending on the temperature. (colder = higher voltage)
