If you made the switch to a hybrid or EV this year and are happy with the savings you're getting on gas costs, a reporter would like to speak with you. Please reach out to [email protected] by 12/5 for more details.
Grinding noise with video
t35t3rt35t3r Member Posts: 1
edited December 2014 in Nissan
Recently reinstalled the passenger CV axle. After some driving, I started hearing a noise, like metal grinding intermittent. In the video there are two examples. In the first 5 seconds is the milder higher pitched sound, in the last 5 is the louder scarier sound. Does not happen on neutral and seems to go away at higher speeds. It is louder out my passenger window even while sitting in the driver seat with both windows open which leads me to believe its not the cvt tranny but just in case, I checked fluid level the right way (warm up, parking brake, cycle gears, check fluid with car running, etc) any help would be appreciated.
Grinding Noise:
  • davidbradleydavidbradley Member Posts: 4
    THERE IS A SHIELD INBOARD OF EACH BRAKE ROTAR WHICH ARE EASILY BENT WHENEVER SOMEONE REMOVES A TIRE, CHECK FOR THIS AS I DID THIS MYSELF
