2016 Outback Battery Dead
I have a 2016 Outback with Eyesight. I sat in my car at lunch last week for about an hour with the radio on. When I came back to my car after work (a few hours later), the battery was completely dead.
With cars that I have had in the past this did not seem to be an issue, has anyone else experienced anything like this?
Answers
Normally I'd guess you could do this for 4 to 10 hours--but that presumes a fully charged battery in excellent condition, with no other accessories or dome or courtesy lights on, and a "normal" radio maybe drawing 50W or 100W.
1. Have the battery tested---a "load test" to see if it's a weak one or not
2. If the battery passes, then I would do a "parasitic drain test" to see if something ELSE---some other small drain, might have been going on while the radio was also draining the battery. In other words, your normal battery drain with everything off shouldn't be more than say 50 milliamps--maybe 100. But if it's like 400 Ma, then sooner or later your battery is going to run down on you--depending on how long the car sits.
