Stalls then won't start till fuel relay reset?
omgitsunknown
Member Posts: 12
So I have a pontiac G6 4 cylinder that has had the fuel pump changed multiple times. I recently took it the dealer they said thwy couldn't find anything wrong with it. I told them to fill the car up with gas because thats normally when it happens they said they did, but when I got it back it still had half a tank. So I went by the gas station and filled it up. As I went to leave the gas station it stalled as I pulled out into the intersection. I pushed it back into the gas station parking lot and called the dealer back. I got it back over there and they changed out the fuel relay its been about a week now and my car isn't starting now fuel pump is kicking on but I'm back to square one. Any ideas? I'm lost and apparently no one has had this issue...
This shouldn't be too hard for a good mechanic, especially since the problem seems to be in permanent fault at the moment.
If you are at a loss for a good technician, you might try THIS WEBSITE---just click on repair shops and see if there's someone near you, or close enough to be towed economically. These technicians are all well-trained.
http://www.iatn.net/
I think you need to dig a bit deeper here and determine if, during the no start, one of the following is happening:
1. The fuel pump doesn't work but the fuel pump relay is energized and working.
2. The fuel pump doesn't work AND the fuel pump relay is not energized
3. The fuel pump and fuel pump relay both bench test perfectly but sometimes the circuit is not energized
I understand that you are saying the fuel pump now turns on when key is turned and runs for about 1 second to build pressure. Then turns off. Normal.
And you are saying the car won't start, even though it would appear to have fuel because of the fuel pump's having just run.
How do you eventually get the car started?
I am not a mechanic but have worked on cars for myself for decades. I have read forums and problems people have had with their H-body leSabres and Bonnevilles since 1993 or so. And have read about Malibus and problems since 2013. Somewhere there was a problem with the car related to filling up the gas tank and something happening that I recall. If I find something that's related, I'll post it back here. I just don't recall which series of cars it's related to.
EDIT: Don't throw parts at this problem. Get it diagnosed. But if you have filled up and it won't start try pushing the gas pedal to the floor and holding it wide open while cranking. This turns off the injectors and clears fuel vapors just like for a flooded engine. If that works, you have another clue, not a diagnosis... Some people say a faulty vapor recovery system on the tank can cause fumes to get into the intake and essentially flood the engine.
That, when the car stalls, it won't restart (sometimes) but it WILL restart every single time you pull out and put back in the fuel pump relay?
Or is that "iffy" as well?
I think you need a good wiring diagram and you have to test all along this entire circuit.
Remember that the fuel pump is energized for only a long second after the key is turned to ON, then it turns off until the key is again rotated. Don't get fooled during the troubleshooting that the pump isn't working all the time while the key is ON.
Leak down pressure drop could be defective fuel pump not holding pressure.
When you turn the key on, do you hear the fuel pump run for a second or two? May need someone with
ear at filler opening to listen unless in a quiet area.
Were any check engine lights on? Any codes?
See if there's another relay in the relay/fuse center that's the same part number that can be interchanged to see if the fuel system functions correctly.
A leaking injector can cause retained pressure in the rail to drop and puts extra fuel into the intake manifold causing flooding...
You may have multiple problems. You may just have a bad fuel pump that's letting fuel pressure leak out when off. What brand did you put in?
A leaking injector would generally cause a single cylinder misfire on top of the other symptoms.
Shiftright and Imidazol have been doing fine advising you, they only way they could do more would be to show up at your house and test what they know how to themselves. Diagnosing this problem is very straight forward but it starts with one key point, forget everything you know about it from the past and test and prove what it is doing right now. Do not assume the no-start right now has anything to do with any previous work. When someone assumes that the current problem is related to past issues, or especially to what happened with someone else's car that is a trap and they can end up wasting a lot of time and money tossing parts that werent proven to be defective.
At this point your fuel pump is not turning on, correct? Do you have a schematic for the fuel pump control circuit?
Any final solution here?
Also, I want to replace the wiring harness my fuel pump plugs into. I think it's in bad shape.
Can this be bought? I can't find it anywhere. Looks like it leads to the relay in the trunk.
2007 Pontiac G6
