If you made the switch to a hybrid or EV this year and are happy with the savings you're getting on gas costs, a reporter would like to speak with you. Please reach out to [email protected] by 12/5 for more details.
Turn Signal Issues
lbarnes8318lbarnes8318 Member Posts: 1
edited May 2018 in GMC
the passenger turn signal starting flashing real fast so I bought a new bulb, put in and the signal was still flashing fast. The fuse is OK. any thoughts..lbarnes
  • PF_FlyerPF_Flyer Pennsylvania Furnace, PAMember Posts: 9,372
    Typically the bulb replacement will do the trick. Could be the turn signal flasher perhaps?
  • rickdonrickdon Member Posts: 123
    Usually, a bad bulb or ground issue can cause rapid blinking.
