Stopping Distance and Grip With 18- and 19-inch Tires - 2017 Tesla Model 3 Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our 2017 Tesla Model 3 has the standard 18-inch wheels and tires, but we wondered if the optional 19-inch wheels offered more than just a different look.
Hard to find any info on the RX version of the ProContact but presumably it is an even newer version, hopefully enhanced performance. Tread design appears slightly more aggressive.
I would also suggest another option: that one doesn't necessarily need to "upgrade" to a 19" diameter tire/wheel. Save the $1500 from the 19" wheel/tire package and just upgrade to a better 18" tire.
Also, I very much doubt that a change to 42 psi from 45 psi is going to make any remarkable difference in any performance parameter for those tires. I think the idea of just going with 18" Contis is a better idea that will return most of the performance increases noted here in the 19" size.
The super-hard rim-protector tires are a bad idea...if I end up spending $500 more for tires every five years for my two cars, due to using more fuel, higher initial price and more frequent replacement, because I buy higher-performing tires, I can live with that. The increase in grip here from .85g to .93g definitely has the potential to transform a crash into a near miss...that's a huge increase, especially considering these was no change in contact patch size.
The Model 3 has a sophisticated suspension design and these Teslas carry their weight quite evenly distributed F/R and very low. The fact of this .9g+-capable chassis transformed into a .85g performer suggests to me how bad these tires are and how much of an afterthought they are - agree that the Conti was the development tire and the MXM4 was tossed on later.
My April production Model 3 is just fine at 42 psi with the new suspension components and the 18" Michelin MXM4 TO tires. A nice blend of traction and range for my tastes.
The other problem with dropping your tire pressure is an increase in temperature-related TPMS alarms. Cars like ours that are placarded at 45 psi are set to trigger a low tire warning at 34 psi (75% of recommended pressure is the rule). Running them at 39 psi gives you a much thinner margin, so you'll need to check your tire pressures more often, especially if the area you live in has large day/night temperature swings. 5 psi can come and go with a passing weather front or a cold snap. Unlike some european competitors, the Model 3 has no "comfort pressure" setting in the menus that would reconfigure the TPMS trigger point to match - if in fact the tire's structural capacity could tolerate such a thing, which isn't a given.
I think we may bring ours in for the suspension upgrade. We've already tried the lower pressure a little, and the car feels sloppier in some ways. Again, a simple tire pressure drop changes more than the tire's ability to absorb sharp-edged impacts. And there's more wrong with the Model 3's ride than just that.
Twitter: @Edmunds_Test
