Do I need an engine oil cooler for my 2008 Uplander?
I have a 2008 Uplander. I have recently started pulling a camper that when loaded weighs right at 3,500 Lbs. This is the maximum the Uplander can pull. I have added a transmission cooler, Air shocks and a weight distributing hitch. The engine really works hard in this hilly part of the country (Southwest Missouri). The Uplander came standard with a small oil cooler - it is basically just a metal tube that runs below the radiator. Do I need to add an engine oil cooler? I would appreciate any input.
Thank you,
Thank you,
Thank you for your input. The temperature gauge stays just over half way up - the same as it is when driving without a load. The transmission cooler is a Hayden 678. It says it is good for pulling a trailer up to 5,000 Lbs. It is basically a radiator without a fan. Before my next camping trip I plan to add a second cooler with a temperature controlled fan. It will go through the passive cooler first then through the cooler with the fan. If the temperature switch (Located between the two coolers) senses the fluid is 180 degrees or above the fan will come on and stay on until the fluid temperature reaches 160 degrees.
but they are discussing that very concern.
The biggest problem with adding more heat exchangers is you risk limiting (restricting) airflow through the radiator and that could result in engine overheating conditions. Even from there, the vehicle is entirely capable of detecting transmission over heat issues which it would inform you about and can even react to cool it down if necessary. One way that it does that is by modifying the torque convertor clutch operation and keeping it engaged at a higher percentage and higher engine loads. By locking up the convertor and limiting torque convertor force multiplication you eliminate the greatest source of heat generated inside the transmission.
The odds are that you really didn't need anything beyond the original cooler inside the radiator. Adding an additional one down stream of the radiator gives you additional capacity but in all likelihood you really don't need it with a 3500lb trailer. Just be sure that the vehicle can pull it with the torque convertor clutch engaged and heat generation in the transmission isn't a concern.
thecardoc3, Thanks for the link I will try to setup the readout for the transmission cooler in the next couple of days.
