Do you currently drive a 2019 Ford Ranger and live in Michigan?
A reporter would like to talk to you; please reach out to [email protected] for more details.
Shifting Issues
iblashauniblashaun Posts: 2
edited August 2018 in Ford
2010 Focus sel Auto Reverse works fine when i first put into gear it goes fine.But when it should go into next gear it revs up if i let off of gas it shifts to next gear. i don't have any jerking or noise like i have read in other places. I have replaced shift solenoid D. transmission shop told me i need to replace trainny. I parked for a long time but needed a diff vehicle one day and decided i might as well drive till falls apart.That was a year ago and still driving so don't think actual trainny but maybe different solenoid or relay. When first started happening got the red wrench light after i drove for a while. But noticed yesterday drove for about an hour no wrench light came on.
AND YES checked fluid level
Answers
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 64,490
    Have you extracted any codes? The red wrench means a problem (perhaps) with the Throttle Positioning Sensor.
  • i have but i don't remember iam going to take friends and have him run them.
    Well when you have them, bring them over here.
  • RumbeeRumbee Saskatchewan Posts: 1
    My wife's 97 buick lesabre has to speed up to 70 80 kms b4 it shifts to speed limit speed it revs up to 4000rpm then shifts rather smoothly no jerks or noise I just put new plugs n wires and new air vac hoses so I'm stuck on why the shifting pattern changed
    Did you disconnect the battery? Maybe the car is in a new learning curve--but this should rectify itself in a day or two at most.
