shuts off while driving
I have a 2003 Chrysler town an country van some time when you are driving down the road
the van will just quit turn key off an back on some time it starts right back some time but not all
time when it don't start back all dash lights are on but it wont grank over turn it off wait a few
min and it starts back some time it will go for a day and be fine the it will quite again.any help
The way to approach this of course is to wait until it happens and then test to see "what has been lost"--either spark, fuel, or, in your case maybe the signal from the ignition switch to the starter and the ignition coils.
Could be a tricky one to solve.
Of course, check your battery cables--both positive and ground, on BOTH ends, and check your fuse box for any signs of corrosion.
Next time it happens, you might also try a "wiggle test" of the harness coming out of the fuse box.
As far as replacing it yourself, you will have to program the SKIM (theft deterrent) before it will start. The computer itself should come from a rebuilder with the current software calibration if it is sourced correctly.
