Power windows/door locks stopped working
krysseijokrysseijo NJPosts: 1
edited October 2018 in Nissan
Hey everyone, I have an 03 Nissan Pathfinder and here is what I’m working on
Passenger front window not working
passenger back window not working
power locks not working
The fuse for the windows is in the main fuse box but check this out, no fuses in that box are lighting up with a test light yet nothing except what is listed below is not working. Any idea why? (Yes the car is on when I am testing the fuses, and I did test them at both ends. Nothing is lighting up)
Can this issue with the fuse box be the reason for the problems above? I was thinking maybe the window motor since there isn’t even sound when I use the window switches.
Help, please
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 64,490
    You should pull the fuses and check with an ohm meter for continuity, just to be sure. You can also test for voltage input with the fuse out.
    Certainly the fuse box can have issues, especially on the back side where you can't see.
