Tires lose pressure with temp change.
cbarlowcbarlow Member Posts: 2
edited October 2018 in GMC
Every time the temperature drops even 10 degrees, I have to air up my tires. I have Cooper Touring [255/60R19] tires. I have had them checked multiple times; the tires have been taken off and resealed, the valves have been replaced but they can't find a reason for it. Does anyone else have this issue? I need to get new tires and I don't want to have to go thru this issue with another set of tires. Thanks for any help you might have on this issue.
  • kyfdxkyfdx Moderator Posts: 270,951
    Air expands as temperature increases, and contracts as it decreases.
  • cbarlowcbarlow Member Posts: 2
    kyfdx: Yes it does, but it doesn't cause tire pressure to drop 10 lbs.
