Water pump
I have 02 Durango with the 4.7. The radiator blew up on me while driving the other day. Apparently it was overheating but due to an electrical issue and the no bus code my gauges will occasionally not work so I couldn’t tell. But that’s a another story for another day. I have another truck identical to this one. I swapped out the radiators and fired it up, let get to normal operating temp. Took it for a drive and it started to overheat again. Which leads me to this question, would this be signs of a bad water pump?
Best Answer
Mr_Shiftright
Member Posts: 64,481
Overheating can be tricky to diagnose, since there are so many different components involved. You could have water pump problems, but unless the pump is leaking, the only possibility there is a broken impeller in the pump itself---a rare occurrence to say the least. You'd have to gauge, once the thermostat is opened, if water is indeed circulating around the top of the radiator (with cap off, you can look in and see the "currents" of coolant). If the water is churning in there, then the pump is good.
You could have issues with the electrical cooling fans not kicking in on time, or failing to work at all. This is usually seen as a low speed, or idling overheat. If the truck only overheats at freeway speeds, or driving around town at moderate speeds, then it could be a circulation problem--like a stuck thermostat.
you could also have a bad head gasket--not out of the question on a 16 year old car. And no, you don't need to see water in the oil for this to be diagnosed. The head gasket leak could be from the combustion chamber only to a coolant galley, not an oil galley. You can test the coolant for combustion gases using a chemical kit you can buy at Autozone or some such place. You can also test by pressurizing the coolant system, and while it is still under pressure, extracting a spark plug or two or six, and looking for coolant on the tip.
Most head gasket failures result in a pretty fast overheat.
5
Answers
Thanks bud, I appreciate the help.
