Rear Hatch
2004 ZR 2. The dash and key fob will open glass hatch but button on gate will not (tests fine). I have 12v at the switch. I checked fuses and replaced the relay in the tailgate (black plastic box shaped with 2 electrical connections) and button still won’t work. I even checked where the wires disappear into the black flexible tubing leading inside the vehicle at the bottom of the tailgate. Someone must have had this same issue?
Best Answer
Optionsthecardoc3 Member Posts: 5,747The button is in series with the lock cylinder switch. Both have to be in the closed position in order to open the glass.
1
Answers
