Toyota Camry XLE-V6
Considering buying a 2000 Toyota Camry XLE-V6.
Anyone have any negative comments?
I pick up a 2000 Toyota Camry XLE V6 today with
HZ,MG,WZ,TN options for $25,692. The color I'm
getting is cashmere beige. I'll post any problems I
notice on this site. From what I hear and have seen,
it's a beautiful car inside and out. Reliability and
quality are excellant.
Joseph
in Vermont
I've found that there are three BEST places to find out about the details regarding options, specs, invoice, reliability and such.
1.) Ultimate Accuracy-> the specific auto website
it'self. For the Camry, http://www.toyota.com
lays out the details but one may find their webpage a bit unuserfriendly.
2.) Ultimately Simple-> Kelly Blue Book is as simple as Edmunds but Kelly lays out the standard equipment and options much cleaner. Thats:
http://www.kbb.com
3.) Ultimate Information and Power to Consumer->
Edmunds is by far the most informative of all. They provide the consumer with easilly accessible knoweldge that is KEY to purchasing an auto with
a sense of confidence. http://www.edmunds.com
By the way..
HZ->extravalue package for XLE(sunroof, leather seats, 6cd changer, side airbags, power seats..
MG-> Mud Gaurds
TN-> Traction Control
WZ-> Alloy Wheel Locks
Have Fun
Joseph
in Vermont
Living in Vermont, I can imagine cars without TC will have a hell of a time thru the winter. Even cars here in South Eastern Michigan are having a hard time without it.
Sweet car. 2000 Camry XLE V6 with sunroof, leather,
climate control, traction control, 6CD changer..the works.
I payed $25,800 including doc fees excluding 6%
tax/registration. I think this car fits me well..and I love
the color Cashmere Beige.
Joseph
in Vermont
It seems to me that the 4 will be worked much harder over the same miles than a 6 would. Just look at the difference in RPMs at 60mph on a 4 compared to the RPMs on a 6 at 60 mph. It's like the little engine that could. It can, but it has to work a whole lot harder to do it.
I would never own a 4cyl. I drive on 2 lane highways and the additional passing time required by the 4 is not something I can afford. I have a '94 Camry XLE, a '97 Camry XLE, and a '00 Camry Solara SLE. All V-6s. On the first two we have had no unscheduled maintenance 70,000 and 26,000 miles respectively. The engines have been perfect.
I rent 4cyl Camrys from Hertz almost monthly on my job. Good cars.....but not nearly as good as the 6cyl. Cost a little more upfront, but worth it.......in my opinion.
Good luck and I would sincerely appreciate any knowledge regarding why a 6 cylinder maintenance would be more than a 4. It never hurts to learn something you don't know.
2.) How can I increase loudness of remote beeps?
As many of you know, I own a 2000 Camry XLE V6.
Does anyone know how, or if it is possible at all, to
increase the distance effectivness of the remote
unlock/lock/panic? It only works for about 15 or so
feet. What's the point of the panic button at that
distance?? Also, I was wondering if it is possible
to increase the beep sounds that occur when you
press a button. They are very dim and too low
to be heard. This is useful when you can't
see your car in a dense parkinglot.
Your help is appreciated.
Joseph Maroun
in Vermont
I can't help you with the volume of the beeps. No ideas there. Presumably the lights still flash on the 2000 models as they do on the older models (once=alarm on; twice=alarm off). If you can't hear the beeps from far away, you should still be able to see the lights flash, no?
Phil
Phil
Seturi
Why don't you use the Search feature at left to find them. This conference focuses on maintenance and repair through the life of the vehicle.
Pat
On the '97 I am hearing what I can only describe as a "groaning, grinding" noise when I apply the brakes. Even if you brake only moderately hard, the front end noses down a little and when the car comes back up this noise is heard. But only if you continue to apply the brakes. If you let off the brakes as the car comes back, the noise is not present.
Any ideas as to what might be causing this? I tested all three cars today and only the '97 made this noise. The '94 XLE and the '00 Solara were perfectly quiet.
Thanks in advance,
Bill
carlady/roving host
