FUEL SYSTEM/PATS
PATS SYSTEM ACTIVATED, JUST REPLACED ECM AND STEERING COLUMN.TOOK TO DEALER TO HAVE KEYS MESHED WITH ECM THEY CLAIM THEY GOT ECM PROGRAMMED BUT CAN'T GET OTHER PART TO PROGRAM. THEY SAID FOR ANOTHER $300 THEY CAN TRY AND IF THAT WON'T WORK THEY SAID ANOTHER $1000 WOULD GET IT DONE. SO IS THERE ANY WAY TO TWIST ANY PATS WIRES TOGETHER TO MAKE IT WORK ? THE PATS HAS DISABLED MY FUEL SYSTEM CAN I RUN CONSTANT POWER TO FUEL PUMP ? WILL THAT WORK?? ANY HELP IS APPRECIATED
Best Answers
Andyg_37
Member Posts: 5
Ordered online all code numbers matchedMr_Shiftright said:Where did you get the ECM?0 -
Andyg_37
Member Posts: 5
Anyone have a solution to this? Someone told me to "ground out the PATS system under the hood"0
Answers
