Help buying used Legacy
I'm looking to buy a used Subaru Legacy for my college son. Mostly interested in the 2010+ model, non-turbos. How are the higher mileage cars, 120-150k mi+? Are these cars pretty reliable? Any known problems? What should I look for/get checked or ask about before buying? Sorry so many questions. Thanks in advance.
The timing belts on these engines need replacement every 105K miles, so it would be good to know when that was last done. If the car is due or overdue, plan on replacing the belt, the water pump, the camshaft seals and inspecting the idler pulleys. This is a common thing to do since you are "already in there".
As for the EJ25 engines... the EJ block wasn't really "fixed" during this time, though they are a good engine. The head gasket issue is their Achilles heel, but, in this generation of Legacy, it was not nearly the same issue as earlier iterations. By this time, failing gaskets tend to manifest themselves as external oil seepage, which gradually worsens to a drip. Internal failure (e.g., oil in coolant or vice-versa, combustion gas in coolant causing overheats) is extremely rare. As a point of reference, my 2010 Forester's EJ25 began showing signs of weeping by about 35,000 miles, and had progressed enough that I finally was able to convince the dealership to replace the gaskets by about 92,000 miles. Even at that point, it was just an occasional drip (but was clearly leaking due to level of oil moisture on the under side of the heads).
Issues with them at 200,000 miles? Well, the engine is ready for another timing belt. It needs a water pump if not already replaced, it may also need an oil pump (both preventative), both of which are simple replacements if already in there to replace timing belt. Beyond that, transmission health (e.g., how well was PO maintaining the lubricant?) is critical at this age (though the tranny can last and last with proper care), the stuff that Shifty noted, and the car may be in need of struts if that was not addressed somewhat recently.
Many are very proud of their old Subaru vehicles, but be careful not to over pay for a car that is nearly used up (statistically speaking), as you may need to put some money into it for continued reliability for your son.
I am not sure on cost nowadays. For HG replacement, I would say probably $2,500 out of pocket from a shop. But, you'll save on timing belt, water pump, and oil pump, because the added cost there should literally be PARTS ONLY, as there is no additional labor needed. I have done this job myself before, and it is quite involved. Parts are around $500-600, so you can extrapolate the labor element. I am not sure about costs of fluid replacement on CVT or differentials, as any of that I do myself. The job is cheap and simple from a parts/supplies/time perspective, so I wouldn't expect a large out of pocket on this one.
Struts, proabably $250 for parts. Shop job? I would guess $600-1000.
I would characterize this vehicle as an excellent "beginner's car." So, as long as you go into it with eyes open and hedge your bets in terms of past maintenance, your son should have a reliable vehicle and can learn a lot of basic maintenance skills from it. In my experience, inspection of three fluids will tell you nearly all you need to know about prior maintenance behavior: Brakes, differentials, and transmission. If those look like they have been there a looooooong time, you may be in for a headache.
The FB engine's "fix" is replacement of the short block. Spendy. I would estimate $4,000+, but I don't know for sure since it is usually covered under the settlement's extended warranty. I had the fix done on my 2013 last September, and it was ~ six years old with about 65,000 miles at the time (I purchased in June of 2017 with ~50,000 miles). IIRC, the coverage cuts off at 100,000 miles and no age limit, but you should check for yourself if you find a vehicle that is a candidate.
I have owned six Subaru vehicles, and the risk of head gasket failure does not keep me up at night. Awareness is everything.
What would be ideal is to buy a Subaru with the EJ engine but with documented proof that the head gaskets and timing belt were already taken care of.
I have a friend who owns a Subaru shop in the SF Bay Area. He takes in older Subarus with head gasket issues (no shortage of them!) and goes through the whole car and then sells them as used cars again----not "cheap" but definitely a lot more bullet-proof!
For me, I would go with 2010-12, all else being equal.
