Will not start
Adamhelms4343
Member Posts: 4
I drove to the store came back out and wouldn't start put gas in it so I put new fuel pump in it I still won't start I just spray ether down intake and I'll start up but can it be please help
Answers
One other possibility, which you could verify with a fuel pressure gauge or by briefly activating the schraded value in the fuel rail, is that the fuel pump IS working and is sending fuel, but your injectors are not opening--that is, you have no injector signal--called "injector pulse". To test this you'll need a NOID light, which is a plug-in that lights up when the injector gets the pulse from the ECM.
