prolonged high idle - frosty weather
sebring2005
Member Posts: 4
Cold start high idle 1200 rpm for 10 minuits then normalizes to 600. warm start high idle same for 30 seconds then normalizes to 600. Other sebrings idle down in seconds and don't go to to high idle when warm. I.A.T. sensor changed, no help. Computer issue or some other sensor failure ?
Best Answer
Mr_Shiftright Member Posts: 64,481You could check the coolant temperature sensor for correct values and also check for vacuum leaks, especially in the intake manifold.
5
Answers
