But, here in CO, it's nice to use them to downshift on slippery roads when you're going downhill and want to avoid the brakes.
2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
It really doesn't matter, all that matters is how well the vehicle responds, but I still find it interesting.
Almost all of them will act like a regular automatic, if you go too slow for the gear.
3 years into my paddle-car, I was still paddling... haha
of driving I do now I guess. I’m more about fuel economy lately.
Audi mastered the dual clutch as of 2006.... with the '06 A3. 106,000 miles on that puppy before I sold it, and the next owner took it to over 150K miles.
I would say reviews were "mixed" on the DSG, but a well-trained and calibrated DSG worked wonders in my opinion. Yes, the transmissions were trainable,and had a "learning" computer "brain." It's important to note they work like a manual, not like an automatic. I personally like the mechanical feel, whereas some people call it a "lurch" upon stopping.
https://www.youtube.com/watch?v=4aB1tbQSUuk
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
https://www.youtube.com/watch?v=X_AMPws3Fv0
"The car has cost me $7,600 to maintain over the course of 215,000 miles. That includes 29 oil changes, 8 air filters, 2 sets of rear brake pads, 2 transmission fluid changes, and 4 sets of tires."
https://drivetofive.com/2019/06/26/platinum-white-pearlescence-2019-acura-ilx-a-spec-review/
That sounds pretty good to me.
June 30, 2019 at 7:27 pm
For your 2013 ILX how many times have you changed the spark plugs after 215k miles?
Reply
tysonhugie Says:
June 30, 2019 at 8:45 pm
They’ve never been changed!"
Hmmm. So I guess Acura's platinum-tipped spark plugs with the 2.4 can last and last.....Although I don't think his engine is direct injected, which is the biggest change since 2013 with the 2.4 v-tech.
I think at this point I'd be replacing them. That can't be a hard job on that car.
compact:
Aclass 2,015
ILX 1,312 +47.1%
A3 831 -58%
CLA 573 -72.6%
2series 473 -18.4%
midsize:
3series 4,927 +38.7%
ES 4,350 +25.8%
Cclass 3,951 -31.2%
A4 2,292 -41%
Q50 2,042 -22.4%
TLX 1,812 -17.8%
G70 1,193
IS 1,560 -19.7%
Giulia 768 -22%
https://acuranews.com/acura-automobiles/channels/tlx-press-kit/releases/2018-acura-tlx-press-kit-powertrain
2.4-Liter Engine i-VTEC® Valve Control System
The TLX's direct-injected 2.4-liter DOHC 16-valve i-VTEC® engine uses an advanced valve-control system to combine high power output with high fuel efficiency and low emissions. The system combines VTC (Variable Timing Control), which continuously adjusts the intake camshaft phase, with Variable Valve Timing and Lift Electronic Control (VTEC), which changes valve lift, timing and duration of the intake valves.
At low rpm, the VTEC intake valve timing and lift are optimized for high torque and low fuel consumption. As engine rpm builds past 4,900 rpm, the VTEC system transitions to a high-lift, long-duration intake cam profile for superior high-rpm engine power.
The "intelligent" portion of the system is its ability to continuously vary the timing of the intake cam relative to that of the exhaust camshaft. This helps boost power and also provides a smoother idle (allowing idle speed to be reduced). The intake cam timing is varied based on input from sensors that monitor rpm, timing, throttle opening, cam position and exhaust air-fuel ratio. The result is increased fuel efficiency and lower NOx emissions.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
2018 430i Gran Coupe
A-class 2,619
ILX 1,224 +34.4%
2series 662 +4.4%
CLA 609 -57.2%
A3 522 -74%
ES 4,960 +4.6%
C-class 3,449 -10.2%
3series 3,392 +6.5%
A4 2,579 -25%
Q50 1,895 -20.9%
TLX 1,761 -13.9%
IS 1,331 -38.2%
S60 1,081+31%
The TLX is a really good car for the money. And for me the most impressive feature is maybe the standard 4-wheel steering, which is something that's optional on a Porsche that costs more than twice as much. The ELS stereo is also quite good.
On the other thread there's the quote for the Infiniti Q50 for $487 a month, and my guess is that for significantly less you could get a loaded V-6 TLX. With the incentives like they are now you can lease a TLX 2.4 for less than an Accord EXL.
Unfortunately, you'd fall asleep and crash.
That 487 is first pencil with zero negotiation ... I am sure that can be 410-425 with some haggling. In all reality for a not too savvy shopper it comes pretty close to the 1% rule and I'd bet many people would sign the deal.
I don't think you can go wrong with either the TLX or the Q50. The TLX is certainly roomier inside, but also FWD biased versus the Infiniti's RWD.
The Infiniti drove wonderfully and I feel I could get into some serious trouble with it. The 400HP version must be a total beast.
