Are you shopping for a new vehicle and having trouble finding one, or have you been waiting a long time for a factory order? A reporter would like to speak with you; please reach out to [email protected] by Tues. 5/11 for more details.
Tire valve replacement
Billy_BBilly_B Melville, NYMember Posts: 4
edited April 2019 in Hyundai
Re: 2018 Hyundai Santa Fe Sport---Is the tire valve and TPM sensor one unit, or can you replace the tire valve stem and keep using the current tire pressure sensor?
  • Michael_DreMichael_Dre New Jersey Member Posts: 7
    From working on Hyundai’s I believe that car is a TPMS that’s a 1 piece design that’s Held on by a nut (usually a 12mm) easy way to tell is if the valve stem is a black rubber piece it’s a 2 piece design that you’d have to replace if you get new wheels and screw in the TPMS to the new stem, if it has a silver nut around the air port you can unscrew that with a deep 12mm socket and remove the TPMS and insert into a new wheel and tighten the nut until snug
    hope that explained it all
  • Billy_BBilly_B Melville, NYMember Posts: 4
    OK...Thank you for your time.
    Bill B
