P0700 help
P0700 code only after installing new shift solenoid and filters ??
The P0733 and P0744 you mentioned earlier mean that the transmission control module is watching the input and output speed sensors and the ratio between them doesn't equal third (the 733) and fourth (the 734) gears. While this can be caused by a faulty speed sensor(s) that failure usually results in issues with every gear ratio. When you have two of the four gear ratio calculations failing its very likely that you have a clutch inside the transmission slipping.
Without testing and proving if a valve body problem exists there is no way to know.
