My 2004 town car remote entry puncher won't open door/trunk etc. It would help to know what fuse it
jshaw3jshaw3 Member Posts: 7
edited July 2019 in Lincoln
Answers
    Before trying to chase down an electrical gremlin, have you checked/changed the battery in the fob?
  • jshaw3jshaw3 Member Posts: 7
    yes,batt. is ok. thanks
    I am reprograming the fob and door punch, and will get back when finished
  • thecardoc3thecardoc3 Member Posts: 5,747
    By "door punch" are you referring to the driver's door outside key pad?
    Yes,now I am, as I re-programmed the puncher ; the door key pad doesn't respond to the factory setting.(although the lighting is on)
    Then the key pad might be failing. With a scan tool that supports the security system you can monitor the data and see which (if any. ) Buttons are recognized when they are pushed.
    I don't think my OBD 2 pocket scan will work. I'll go to AZ and check it. THANKS
    I would not expect what Autozone uses to work either, not saying that it won't but there is a big difference between professional level tools and what the average consumer has available to them.
    Thanks guys,going to sell "as is"
