Homelink and Garage Door Issue
verybeegverybeeg Posts: 19
edited October 2017 in Acura
I am posting this in case others have issues like I did. My RDX's Homelink buttons hadn't been working with my Chamberlain Liftmaster garage door opener for a year. I finally spent an hour today researching online then talking to Homelink and got it figured out. Homelink has great customer service. So if my steps here do not work for you, just give them a call.
Follow these instructions first to program RDX Homelink with a Chamberlain, extracted directly from Homelink's website http://www.homelink.com/:
  1. For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
  2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
  3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
  4. Press and hold the trained HomeLink button and observe the indicator light.
    • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
    • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
  5. At the receiver (motor head unit), locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the device owner’s manual.
  6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer).
    NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
  7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
    Retain the original hand-held transmitter of the RF device you are programming for use in other vehicles, as well as for future HomeLink programming. It is also suggested that upon the sale of the vehicle, the programmed HomeLink buttons be erased for security purposes. To erase the programmed buttons, perform the procedure shown in step number 1.
After completing these steps multiple times, I still couldn't get Homelink to work. So I called Homelink and they had me do a factory reset: Press all 3 Homelink buttons until the LED flashes rapidly and then turns off, this took around 30 seconds.
Afterward, we redid all the above steps. After programming, he had me press the Homelink buttons. The Homelink button I was programming was flashing rapidly for a few seconds before turning off, meaning it was talking to the garage door opening. The other 2 buttons were just slowly flashing, meaning they were not programmed. Then he had me check if the garage door Learn button LED flashes as well. (Best if you can have another person looking at the Learn button while you push the Homelink button.) I was by myself, so I pressed the Homelink button, then ran inside quickly and did see the Learn Button LED flashed several times before going off. Flashing meant it was also receiving a signal from the Homelink button. This showed the Homelink button and the garage door opening were communicating.
He then asked me if I had LED light bulbs in the garage. Indeed I had replaced them a year ago. (BINGO!) Turned out LED light bulbs use frequencies that sometimes interfere with the Homelink buttons. We have a Lexus with Homelink which worked fine, but somehow they interfere with the RDX's. When I untwisted the bulbs, the Homelink button worked immediately.
So if your Homelink button doesn't work or work intermittently, see if you have LED bulbs or other electronics nearby that are interfering. This would save you tons of time and frustration.
  • kyfdxkyfdx Posts: 152,813
    Those instructions are good for just about any make or model. Just did my wife's new 2017 BMW, exactly the same way.
    Nice tip on the LED bulb.
  • My garage door opener is over 20 years old with no LEARN BUTTON. However I was able to program opener only by having car under receiver antenna. Trying to program outside or operate the doors from outside didn't work because of metal garage door and metal siding on house. Homelink support could only suggest a new receiver. It seems the Homelink transmitters in my new Buick are not as strong signal-wise as the old visor clipped ones. So, I Stripped insulation off end of antenna wire of receiver and spliced a length of 20ga. insulated (dog fence) wire to antenna, across ceiling and down along inside frame of garage door. Vola! Works good just outside garage with door open or closed. I might try running wire down vertically along OUTSIDE of door frame for even better reception.
  • Mnorto3Mnorto3 Posts: 1
    Thanks for this!  I had just installed an LED light in my opener and could not understand why it opened, but did not close.  Once I removed the bulb, everything worked as it should.
  • John_S_SE_MIJohn_S_SE_MI SE MichPosts: 1
    I had a 2yr old Genie 3055 and ~6mo ago I put in LEDs. In the last few weeks my homelink stopped closing the door (3 diff cars). I read this post and replaced the LEDs w/ the old CWFs. Homelink works great again at closing the door. Thanks for this post. I was thinking the motherboard of my Genie opener was going bad.
  • BobGVegas1BobGVegas1 Las VegasPosts: 1
    I have a 2017 Acura RDX that had the same problem with Homelink. I went through all of the suggestions above but it would not open and close the door. Then I noticed the LiftMaster antenna did not have any exposed wire. I stripped the antenna back by about 2 inches and tried to link Homelink to the LiftMaster one more time and it worked. The completely sheathed antenna worked fine for the 4 other cars we have had but not the RDX. Anyway, now it works so if you run into linking problems you may want to check the antenna. Good luck.
  • GeorgeSugarwoodGeorgeSugarwood Clay, NYPosts: 1
    I am so happy I came across this post but I still have not found a solution so maybe I am doing something wrong.
    See, I installed an overhead LED fixture light in my garage while plugs into the ceiling socket and another LED bulb in the socket itself about 6 months ago.
    When I came home last night, my homelink in the mustang wouldn’t open the garage door. The key pad on the side of the garage door wouldn’t work either. I went in through the house and the wife did leave the garage light on (this LED lights). I tried resetting my homelink and exterior keypad and had zero luck and tons of frustration.
    I came across this post and hoped it was the answer so this morning I unscrewed the LED bulb and the overhead LED fixture was off (but plugged into the ceiling socket). I followed all the steps in the post and STILL can not re-connect my homelink OR exterior keypad.
    Is the LED fixture simply being plugged in (but off) causing the interference? Cause i have never had this issue in the past with it simply off.
    I have not looked to see if my craftsman unit has an antenna wire that i could sheath shielding off of yet.
    Any additional help or guidance would be much appreciated!
