Tom
I have a 2018 Jeep grand Cherokee Limited. The dealer said this car is NOT equipped with Auto High Beams. (If you are not familiar with the feature, the car senses that the road is dark and turns on the high beams. In the event a cor is coming towards you, the high beams will be dimmed.)
My 2005 Grand Cherokee had it.
Can anyone tell me how to determine if it should have it based on the sticker info. Thanks
Best Answer
PF_Flyer
Member Posts: 9,372
Wouldn't it be a setting on the control stalk? Found the manual online, and "if equipped"...
The Automatic High Beam Headlamp Control can be
turned on or off by selecting “ON” under “Auto High
Beam” within your Uconnect settings, as well as turning
the headlight switch to the AUTO position. Refer to
“Uconnect Settings” in “Multimedia” for further information.
If you don't have an Auto setting on the control stalk, I'd say it's not equipped5
Answers
