blend door
boppascott
Member Posts: 42
I broke the post on my hot/cold blend door and had it screwed/epoxied for 2 yrs now it is loose again and won\t stay together with epoxy.How hard is it to replace the blend door itself or should I just continue to change from hot to cold manually?(I drilled a hole in the plastic and use a thin hooked rod) Thank You in advance
https://www.youtube.com/watch?v=9Z4q6s5pECw
