2020 BMW 3-Series Lease Deals and Prices
1383941434458
  • kyfdxkyfdx Moderator Posts: 236,760
    cdbmw330 said:
    Sysy62 said:
    Please send numbers for 330xi looking for MF, RV, incentives and loyalty. 36/12 zip 02026
    .00099 MF and 58% residual
    $750 lease credit
    $2000 loyalty
    Is the residual the same for the 330i RWD for 36/12?
    Yes, either drive
    Looking for the incentives, residual and MFs on a 2020 330xi
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    .00099 MF and 59% residual
    $750 lease credit
  • ldeleon96ldeleon96 Member Posts: 35
    Can someone please give me the MF, RV and incentives for a 2020 330i and m340i for zip 89148. 36/12 Thanks!
  • ShowBoneShowBone Member Posts: 16
    edited July 2020
    Hi! May I know incentives, RV and MF for 2020 BMW 330xi, 36/12k miles
    Zipcode: 60056
  • kerbkerb Member Posts: 195
  • MichaellMichaell Moderator Posts: 240,982
    .00099 and 58%
    Lease credit
    330i - $750
    M340i - $1000
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
    Zipcode: 60056
    .00099 and 58%
    $750 lease credit
  • akbmwakbmw Member Posts: 1
    Can I please get the MF, RV and incentives for the 2020 BMW 330i, 24 months, 10K miles @ zip code 95134
    .00099 MF and 63% residual
    $750 lease credit
  • persianaraspersianaras Member Posts: 41
    BMW is accepting multiple security deposit again? I know they took that option away a few years ago. What's the max number of SD's you can put down now? 7?
    Thank-S
    Magyar001 said:
    Looking to lease 330i xdrive MSRP 52,875
    66007
    10K/36 month
    Can anyone let me know if 60% is residual value and what the money factor is with multiple security deposits? Dealer is taking 4500 off MSRP with zero down option.
    .00118 MF and 60% residual
    $750 lease credit
    .00083 MF with 7 MSDs
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    Thank-S
    66007
    10K/36 month
    $750 lease credit
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    Still max 7 MSDs, but the decrease per SD is now .00005 (formerly .00007)
  • bm3fanbm3fan Member Posts: 20
    Are MSDs even worth it? According to a source from a search engine, the MF from 7 payments equates to 0.84%. That doesn't even offset the 2-3% inflation rate. Unless my math is too simplistic...
    It is..
    The easiest way to see the difference is to calculate a payment with .00099 MF, and then again with .00064 MF. Then, multiply the payment difference by 12, then divide by the MSD total amount. The result is the after-tax return on your MSDs.
    Just to confirm, the max 7 MSDs= 1 required SD+ 6 additional SD ? (not 1 required+ 7 add= 8 total)
    So if I want to put down the 7 max, the total reduction is 0.00035? (not 0.0004)
    Thanks so much.
    Thank-S
    66007
    10K/36 month
    $750 lease credit
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    Thank-S
    66007
    10K/36 month
    $750 lease credit
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    Thanks so much.
    Thank-S
    66007
    10K/36 month
    $750 lease credit
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    Thank-S
    66007
    10K/36 month
    $750 lease credit
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    Zip code: 10075
    Term: 36/10
    Thank you so much!!
    66007
    10K/36 month
    $750 lease credit
    0 SD + 7 MSD = .00035 MF reduction
    Generally, BMW does not require an initial security deposit on a lease.
  • polo7polo7 Member Posts: 3
    Would you please share MF, RV, discounts, & incentives for:
    2020 BMW 330i
    2020 BMW M340i
    36 months, 10K miles for ZIP 33178?
    2020 BMW 330i
    2020 BMW M340i
    330: $750 lease credit
    340: $1000 lease credit
  • naive_bluenaive_blue Member Posts: 1
    Can I get incentives, residual, and MFs on a 2020 M340i?
    Zip code: 95054
    Term: 36/10
    Zip code: 95054
    Term: 36/10
    .00099 and 59%
    $1000 lease credit
    Hi, for the 2020 330i; 36/10, are they offering $750 lease credit AND $2000 loyalty or is it one or the other? Thx in advance.
    You should get both, if you qualify for loyalty
  • GTRacer19GTRacer19 Member Posts: 3
    edited July 2020
    Hello!
    Can I get the RV, MF And incentives into a 2020 m340i xdrive zip 20164 at 36/10k
    GTRacer19 said:
    Hello!
    .00099 and 59%
    $1000 lease credit
    For incentives, lease credit, loyalty, etc, does it matter which state (or zip code) you're in? If it does, can you confirm what's available for Arizona? ($750 lease credit, and $2000 loyalty?)
    zipcode: 85712 or 85054, if needed.
    Thx!
    Thx!
    Incentives on the 3-Series do not vary by location
  • Sgraziano89Sgraziano89 Member Posts: 49
    Hello, Could you provide the MF, RV (36/10k) and incentives (lease credit, loyalty, etc) for a 2020 330i and 330i xDrive in 02052? Thanks!
    $750 lease credit
  • Adamd06Adamd06 Member Posts: 22
    Hello, could I please have RV, MF for 330i xDrive 36/15 for 08054. Also, I am from PA trying to buy in Jersey. Does that matter for RV or MF? Is it from where I am located 19026 or from where the dealer is at 08054. Thanks
    Dealer location
    .00099 and 56%
    $750 lease credit
  • newcar_2020newcar_2020 Member Posts: 6
    Hello, looking for MF and Residual for 2020 M330xi, for 36mo/10k lease in 07079. Thank you
    $750 lease credit
  • francisco867francisco867 Member Posts: 4
    edited July 2020
    Could I have MF and RV on the 2020 330i xDrive please? 36/12. Zip 55402.
    Thanks much.
    Thanks much.
    .00099 and 58%
    $750 lease credit
  • moparguymoparguy Member Posts: 1
    What's MF, RV on 2020 330 and 340 36/10 zipcode 92019.
  • CFr3dCFr3d Member Posts: 6
    Can I get the MF and Residual for a M340i AWD in 46077? And current incentives.
    Chris
    Chris
    .00099 and 56%
    $1000 lease credit
  • wizziewizzie Member Posts: 8
    Hello, I am new to leasing. Have been to multiple dealerships with prices all over the place for the M340x drive. Definitely frustrating.
    Best deal-
    MRSP- 61,995
    7k trade in
    3k down
    Loyalty incentive
    580k/mos for 36 months, 15k miles
    Is this a good deal? Thank you!
    ALSO can I get the MF and Residual for a M340i AWD for 06611? And current incentives
    Best deal-
    MRSP- 61,995
    7k trade in
    3k down
    Loyalty incentive
    $10K up front, between the trade equity and the up front cash?
    No, that is not a good deal.
    .00099 and 56%
    $1000 lease credit
    $2000 loyalty
    Use this link to help with your pre-incentive pricing:
    Yes for a total of 13K up front when adding in the lease credit and loyalty
    The problem is that the other dealerships wanted same up front and 700-800/month so this was best I got. I am shocked at the inflation and not really sure why there is such a big difference between offers
    I also forgot to mention that the tires, rims and dents warranty was added to the quote which adds another ~$2800
    $10K over 36 months is $278/mo, so that offer is really $850/mo.
    Not the best; not by a long shot.
    Ask one of the dealers you are working with to provide a copy of their lease worksheet.
    And, read back the last page or two to see what others have been able to negotiate.
    thank you, I will do that
    Chris
    .00099 and 56%
    $1000 lease credit
    Thank you... what about 36/12?
    CFr3d said:
    Chris
    .00099 and 56%
    $1000 lease credit
    58%
  • guvely90guvely90 Member Posts: 1
    edited July 2020
    Final deal for 2020 BMW 330iX for 3-year/12k miles in TEXAS Dallas ZIP 75010
    .00099 and 58%
    $750 lease credit
    Hi-
    Can someone please advise if this is a good offer:
    2020 330i xDrive MSPORT
    MSRP $52,395 (incl destination charge)
    Selling Price: $46,640
    Incentives: $1,750
    MSD $3,150 (max)
    Lease 36 mo/10k
    Drive Off: $3,795 (1st months, upfront fees, upfront taxes) (not including MSD)
    Residual 59%
    Monthly $437
    What do you think?
    Hi-
    Incentives: $1,750
    MSD $3,150 (max)
    Lease 36 mo/10k
    Residual 59%
    Monthly $437
    What do you think?
    New Jersey (07079)
    Hi-
    Incentives: $1,750
    MSD $3,150 (max)
    Lease 36 mo/10k
    Residual 59%
    Monthly $437
    What do you think?
    New Jersey (07079)
    Counter with $450/mo and only $1500 out of pocket (excluding MSDs) and see what they say.
