Dodge Dakota - General Topic
EXAMPLE:
http://www.geocities.com/maldbnsf/Dualback.html
Here are 2 links with pictures of Daks with dual exhaust out the back (like you describe)
http://home.ec.rr.com/blackdak/mods.htm#MBRP
(this one KEEPS the spare tire)
http://www.geocities.com/dak2nv/magnaflow.html
Here is a small sample of exhaust links from my research. (I will leave it up to you to figure out which one I have on my Dak ;-))
http://www.mbrp.com/
http://www.gibsonperformance.com/
http://www.bbexhaust.com/
http://www.truckaddons.com/Catalog/subpages/Borla1.htm?CP1=Goto&a- mp;a- mp;a- mp;CP2=borla
http://www.borla.com/
http://www.bosalperformance.com/
http://www.edelbrock.com/home.html
http://www.exhaustproslinc.com/index.html
http://www.jardineproducts.com/
http://www.magnaflow.com/01home.htm
Anyone who can cite reasons why I should lease a Dakota over a Nissan Frontier or Toyota Tacoma aside from the fact that I hate Toyotas and their lying dealers. Am considering leasing American trucks now coz Consumer Reports showed that the Dodge Dakota is reliable. Aside from the Dakota which one among the American cars is a better choice? Does the Dakota have a V6 and sideairbags.
I wanted to dispose my RAV 4 last week but my wife lost the cargo cover when she went shopping at Costco. Toyota wanted $600-700 to replace it, got a replacement for it from ebay for $200. Now am ready to trade-in, or maybe trade lease.
Thank you for all your responses
My main objective was to be able to load my ATV onto the bed of a truck and close the tailgate. This was not only impossible in the Frontier, but the four-door version of that truck had extremely disappointing rear seating.
Guys with the V6 Frontier are reporting slightly higher fuel mileage, but not much. This summer my 4.7 V8 auto had an average of over 18 MPG. The Dakota is solid and quiet and more than quite comfortable.
Best regards,
Dusty
Hmmm. I once participated in a major wiring repair on a '71 Dodge Coronet that had been hacked up. All of the firewall wiring had been cut at the connectors (Hemi engine was stolen).
We were able to order all of the wiring harnesses at that time. Of course, that was 30+ years ago.
So what happens should a Dakota catches on fire or something? Still, I find it hard to believe that the harnesses are not available from the factory.
Try another dealer. Maybe the parts guy wasn't savvy enough.
Good luck and best regards,
Dusty
In the literal context of what you wrote in the above, no, it is not a common thing.
There are many, many reasons for a check engine light. You need to get the fault code out of the system. Starting with the ignition switch in the off position, move the switch to the on position three times, stopping in the on position. Observe the oddometer section of the instrument cluster. You should see a fault code displayed (if you have a fault) starting with the letter "P."
Come back here with the code and someone can ggive some indication of where the problem might be.
Dusty
To get more info, simply turn the ignition key from off/on/off/on/off/on (without engauging the starter motor) Odometor will then display the diagnostics and reveal any troublecode that exists. Look up the troublecodes on any OBDII website.
http://www.allpar.com/fix/codes.html
http://www.obdii.com
Then, you will be 'armed' with the knowledge of specifically why the CEL came on.
Good luck
Tom.
Dusty
Glad to see you got things working.
Best regards,
Dusty
He seems to think that AWD would be all around better in the snow.
Thoughts?
Bests,
Dusty
I also heard that when going around a slick curve in snowy or icy conditions, a typical part time 4wd system with the center differential locked can cause your vehicle to spin out. That might be part of the reason you see so many trucks in the ditches with the greasy side up when the weather gets bad. For both of these situations, a full time or AWD mode with an open center differential is better.
However, with the Dakota, you can get the best of both worlds with AWD and a real low range for off roading (I think the low will lock the center differential, someone can correct me if I am wrong). This system is one thing that might lean me towards the Dakota when it gets time (when my wife lets me) to replace my truck.
The "open differential in the xfer case" system is stupidly simple to add to any 4WD vehicle and then call it "Full time four wheel drive" There are many drawbacks to this system. The worst one is that when ANY ONE WHEEL SPINS -- you are stuck. Also, cornering on slippery roads will almost ALWAYS end up with your outside-front wheen breaking loose first. You immediately end up with no steering control. During the rest of the year, your tires will wear out about twice as fast as normal AND you will tend to be replacing drivetrain components too (front axles and CV joints) This system also reduces MPG because of all of the drivetrain churn.
Somone mentioned vehicles in the ditch... this type of "open differential in the xfer case" is exactly the cheepo type of AWD system that can cause this to happen.
The system I just described above is what is available in the Dakota.
Just because the Dakota-Durango is related to the Jeep (engine and trannies) DC does NOT put the Jeep xfer case into the Dakota. If you want a real AWD system, DC wants you to buy a Jeep.
Bottom line: Dont get the "Full time four wheel drive" in the Dakota-Durango platform. It is not nearly as good as REAL 4X4 that can be put into 2WD in the summer time.
DC = Damlier Chrisler
Bpeebles, so the Dakota AWD system is just a center differential added to a conventional 4WD? If that's the case I guess I'd have to agree that it's not optimum. The impression one get's from the term "all-wheel drive" is that power is applied to all wheels under varying road friction conditions.
I recommended to this fellow to consider a conventional 4-wheel drive with limited slip in the rear. This usually gives you three-wheel drive under many (most) conditions when in 4WD, since Dodge doesn't offer a locker.
Yeah, I thought about the driveline wear and tear, too. Seems like a lot of people I know with AWD mini-vans have a problem with the system after they collect some miles.
Still, this guy might trade-off the disadvantages for the better traction in snow. His wife has a Subaru and he's impressed with the way that car goes through snow.
Bests,
Dusty
I'm not an off-roader. Some friends say the 2wd set up should be fine. Others cite the "4wd holds value" plus traction in New England winters arguments. My brother says to get 4wd, not mention it to Saabgirl and hope she doesn't notice the insignias on the fenders.
But, heck, for a long stretch from the 1960s-80s I drove RWD sedans with no traction assist at all through all that Pennsylvania could throw at me.
Plus, as a retiree, I usually have the option of looking out the window and saying, "The heck with it."
All advice is appreciated.
Keep in mind that the terrain is generally flat with rolling hills so I don't have to deal with mountains. Rick
Are you sure that on the Dakota full time 4wd you can spin one tire and get stuck? That does not make sense, and it is not like some other full time 4wd vehicles I have driven. Does putting the vehicle in 4wd low lock the center differential?
If you are right, I back off on my endorsement of the Dakota with the full time 4wd. However, while I do not live in Vermont, I still think that a real AWD system (that varies power between the axles) is superior to a part time 4wd system with a locked center differential in the snow and ice, and I still think that a locked center differential at higher speeds and in slick conditions can cause you vehicle to spin as compared to a real AWD system. However, when you are doing serious, low speed off road duty, a locked center differential is a must.
Long time since I've posted. But that has been probably due to the fact that up until now my 2002 Dakota Sport Quad Cab, 2wd, LSD, 4.7 with manual trans. has been ironclad. I have 65K on this baby and have not had to take it to the shop for anything except a tune-up. Even the brakes have held up well, although I do live in mountain less Florida.
The problem I have recently experienced is resistance when shifting into first gear. Sometimes it is so bad I can't shift into first at all without moving the gear shift around a little or shifting into second (without engaging the gears) and then back up to first. It is becoming annoying enough that I'm ready to take it in for a repair if necessary.
The question I have is that at a little over 50k I had the transmission fluid replaced with Synthetic Red Line. While underneath for my last few oil changes I have noticed very minor amounts of transmission fluid in and around the exposed threads of the transmission drain plug. If it is leaking, it must be extremely slow as there have been no drips or puddles in my garage. Could this slow leak be causing the resistance I am experiencing when shifting into first gear? Those of you who remember me will also remember that I always freely admitted to not being mechanically inclined (though I am improving). How do you check the fluid level in the manual transmission? And if it is low/leaking, how do you add more? I had a shop do the fluid drain and replace. I wanted some opinions and perhaps a self fix before I take it in.
Although it has been a long time since I posted I have continued to be an avid reader and have enjoyed all the information I've received and learned from. For those interested I regularly average 17 mpg. city driving and 21 mpg hwy. I'm disappointed with the exterior look of the 2005 Dakota and that a 5.7 is not (just currently?) an option. I think the Durango looks like a Minivan on steroids and the Dakota exterior designers had writers block.
Patrick
Searched the problem on the DML archives and someone else had the same issue after switching to Redline, but there were no solutions.
Was thinking of trying Redline to see if it would solve this, but obviously that doesn't seem to be the fix. The 5-speed tranny fluid is the one fluid that Dodge says "does not require periodic changing".
Took it to Dodge before the 3 year warranty ended and they said it was possibly a worn clutch, and to open it up and take a look for another problem would cost about $800, which I would be liable for if it was indeed the clutch. I argued a bit with the service manager, to no avail, and then took it to a local tranny shop, and they said it could be the clutch, or a couple other things (possibly a pilot bearing, if I recall), but they wouldn't know until they opened it up. I said I would wait to see if it got worse. 2 years later, it hasn't really gotten any worse. I can usually get it into first gear if I force it a bit, or shift into another gear first (pumping the clutch does not help). It also slides into first easily when coming to a stop at around 5MPH. Interestingly, the problem seems to lessen when the weather gets colder (below 0ºF), but comes right back in the spring, or on warmer days.
I haven't abused the tranny or clutch, and am a very light shifter (no 4000 rpm drops, or feathering the clutch, etc).
Truck hasn't had any other serious problems (not that this is serious........yet).
You check the fluid level by taking out the fill plug on the side of the tranny and sticking your finger in (I think you use a 1/2" socket drive to back out the plug). The level should come within 1/4" of the top, or leak out slightly.
2000 CC 4WD 4.7 5-speed LSD 48,000 miles
A 2WD system will avoid the higher initial cost, added weight, poorer mileage (my 4x4 @ 65K has cost almost 2x as many $ in gas than an equivalent 2WD), and a 2WD truck sits lower and will be easier to get into and out of. I'm 6'3" and in certain situations when the ground tilts away from the truck, it's a chore to get that first a__ cheek on the seat. Hey, I'm not that fat either!
I think you're on the right track. I've been pleased with my 4x2 Club Cab with limited slip and the Goodyear SR/A tires for winter traction. I throw four seventy-pound sand bags in the bed and it does an admirably job. It's not FWD or 4WD, but I've found that the limited slip makes a big difference.
When I put my 650 lb. ATV in the back it makes a dramatic difference. Then I can go just about any where a 4WD would go in snow.
Bests,
Dusty
Dusty
Technically, on any tranny, there are 2 possible reasons to have problems going into 1st gear;
1) Clutch not fully releasing
2) 1st gear Synchronyser is misbehaving
Obviously, the easiest and cheapest thing to try first is to change the xmission fluid. Any other corrective actions may be costly and not worth messing with anyway.
BTW: A clutch problem usually will be seen going into EVERY gear.
Great idea! Thanks.
>>I'm 6'3" and in certain situations when the ground tilts away from the truck, it's a chore to get that first a__ cheek on the seat.<<
I'm on the vertically challenged side, so I could really have trouble.
>>When I put my 650 lb. ATV in the back it makes a dramatic difference.<<
Hmm. I could tell Saabgirl that a new ATV would still cost less than 4wd. Wonder if she'll go for it? Thanks, all.
During our conversation, the service manager noted that he couldn't remember ever seeing a 2WD unit go through the shop. This is the same service manager I was dealing with in '00 too. Kind of interesting if he's remembering right. We're sort of "farmy" around here and maybe that has something to do with it.
Over the last 1.5 months, as the night-time air temps have decreased to 10 deg F (going back up some now), I've monitored and added more air to 12 tires on 3 vehicles. Kind of amazing how much the pressure has decreased (Charles' & Boyle's Gas Laws) every two weeks or so as we got deeper into winter.
To get the maximum miles out of your tires - maintain proper tire pressure.
Happy holiday season to all,
Bookitty
Thank you for the information. At the very least I am happy it's not a major problem.
Patrick
My 4.7 normally idles almost glass-like most of the time. About 2-7% of the time it does it's slightly bumpy thing when the idle speed drops about 50 RPM. I do not believe this is related to the spark plugs, however. This is a symptom exhibited by some 4.7s. It's only slightly annoying, mostly because I know this engine can idle as smooth as a jet. I suspect that this is the result of a slow sensor response somewhere in the system. Switching into the defroster mode raises the idle just enough to eliminate the bumpy idle.
Best regards,
Dusty
Ron
The full time system available (in AWD mode) splits the torque evenly between the front and back. Therefore, you cannot spin only one tire. Also, the full time system has a locking mode in both the high and low range positions, in case driving conditions are severe.
Yes, full time 4wd will increase some wear on your drivetrain and cost you a couple of miles per gallon economy, but it is flat wrong to state that you will wear your tires out twice as fast.
I have a Subaru Forester XT and a Mazda B4000 with part time 4wd. Having experienced both systems on and off road in a variety of conditions, I would gladly trade off some small additional costs to have the security of AWD in my pickup. In wet conditions, which are not appropriate for engaging a part time 4wd system, an engine with torque and light pickup rear end make getting traction a challenge. While a lsd helps some, it also makes the vehicle more likely to fish tail in certain conditions, as it is still easy to break both tires loose. And don't tell me to carry around 500lbs in the back, because that will decrease fuel economy and increase wear and tear also, and is generally a pain in the rear to move in and out of the truck when you need to haul something else.
To me, the Dakota will full time AWD (which can be locked in high and low) seems to be the best of all worlds for a pickup, and should definitely not be maligned as one of the worst and cheapest systems, because this is just plain not true. In fact, the full time AWD is one of the factors that is keeping the Dakota in my consideration for my next truck. And besides, if for some reason you still hate AWD, you can still get a part time system on your Dakota if you so wish.
Not trying to start a flame war here, but we are relying upon each others input. Let's try to make sure what gets posted is true. Otherwise, the value of these discussion groups goes down the drain.
Happy Holidays!
I've noticed that every manufacturer can offer mechanically different AWD / 4WD / traction control systems and then their marketing departments call them whatever to make it sell. This can and does generate a lot of misunderstandings by us the end-users.
Let's hear from an AWD Dakota driver - quick.
On the subject of the AWD system available on the Dakota. I have a co-worker who has an 02 QC with AWD. Last winter I asked him if he could spin both the front and rear wheels simultaneously in slippery conditions while in AWD (not 4WD Hi/Lo) and he said yes. That would tend to indicate that the power is split between the front and rear. Somewhere, I vaguely recall reading that the torque split was something like 60% rear/40% front. But, I am not 100% certain as to the accuracy of my memory. New Venture Gear doesn't have much info on the AWD transfer case on their website.
We now need somone with a 2005 shop manual (with engineering training) that can interperet the engineering drawings..... anyone?
It is a nice story that somone can SAY that they can "spin" this many or that many tires... but I rely on true engineering and not what people say.
BTW: There is no question that so-called "full time" drive systems will promote increased tire (and driveline) wear. Anyone that beleives otherwise does not undestand the physics behind how vehicle drive systems are designed and react under operating conditions.
Also, I personally beleive that losing 2-4 MPG is a VERY UNDESIRANBLE tradeoff. I have 'run the numbers' with several variables (tire cost, driveline cost, fuel consumption... etc) over 150K miles of owhership and I cannot justify the monatary costs of a "full time" drive system.
As I have detailed in past postings, my factory-orderd 4WD dakota with the options I selected has the best of both worlds. (reasonable 21MPG in 2WD while having tremendus tractive abilities in knee-high snow.) Even here in Vermont, I do not need to enguage 4WD more than a month out of each year.
The bottom line is that each person needs to decide for themselves what they are comfortable with to help them drive under slippery conditions. .... Just please do not think that 4WD will help in any way while driving over 40MPH. There are other forces of physics that overshadow any forward tractive requirements of a motor vehicle at those speeds. (like braking and lateral traction)
A 2WD vehicle with "Hakkapeliitta WR" tires on all 4 wheels is MUCH safer in the snow than any 4WD with "all season" tires. If one is looking for safety, the proper tires are a much better choice than any 4WD system ever invented.
http://www.etires.com/nokianbrand.html
SURPRISE: 4 wheel drive systems ONLY help you get moving. Cars have always had "4 wheel braking". Lateral traction cannot be altered with any drive system. (only tire choice can affect that)
No clunking and it seems to be steering fine.
When I went to pick it up, the service guys were in the beginning stages of "tearing their hair out" with scheduling since more owners had gotten their letters and calling.
I have owned/driven both the 00 Dakota Quad cab in both part-time and full-time(AWD) versions
1st Dakota Quad--> Special Order(New)
'00 Quad Sport+ 4x4(part-time)
4.7L, 5-sp, 3.55, Anti-Spin
Wheel/tire option with 31x10.5
**(1) winter of snow driving @ about 8"
[T-Boned some A**Hole who pulled
out in front of me and totaled
@ 17,000 miles]
Current Quad--> Bought used with 3,000 miles @ dealer
'00 SLT+ 4x4(Full-Time)
4.7L, Auto(multipseed)
3.55, Anti-Spin
**Currently 52,000-mi &
(3) winters of snow driving
with anywhere from 1"-12" snow
MPG Comparison
-- 4x4(PartTime) 5-sp = +/- 19.5 mpg
-- 4x4(FullTime) MultiAuto = +/- 15.5 mpg
I have a '00 shop manual, and am a registered P.E.(structural) who can read tech drawings and agree with bpeoples that the dakota AWD system uses an OPEN front differential. From what i recall when i ordered my first quad, the AWD option was only +/- $100 so it can't be too much extra equipment. I'm not sure how much it is now.
As far as what i have been able to gather, i have noticed no difference or advantage while driving on dry and wet road conditions except the loss of 3.5-mpg (some of which is do the the auto). I have, however been able to tell an EXTREME difference when in snow(loose powder, packed, slush, etc) and deep/loose mud. With the part-time truck, unless it was locked in 4wd, it was squirrly(the antispin only helped marginally). With the AWD truck, the normal AWD setting(un-locked) was all that was needed 90% of the time except when the chassis/bumper was dragging/plowing snow.
Honestly, unless you are somewhere where snow layed on the roads 2-4 months out of the year, i would go with the part time. The AWD option was not something i was especially looking for(actually i almost did not buy the truck because it had it) because of the extra wear-and-tear on the driveline components, not to mention the extra effort needed to pull and turn all the parts/pieces ALL THE TIME, which i notice everytime i pull into a gas station. Believe me its not driving style because i have been accused of driving like a 90 year old many times.
If you live somewhere like i do in rural central North Carolina, where it might snow 3-weeks out of the year, your biggest bang-for-the-buck option would be the anti-spin and the ABS with the part-time set-up. I also preferred the 5-sp to the multispeed auto, just because i like to be able to determine my own shiftpoints. And trust me, my manual shifting was allot smoother than the multispeed auto most of the time.
Also, if you do live somwhere where it snows often and deep, when you put sidesteps on, go with the tubular nerfs and do not put the solid extruded type. Its like bolting a set of skis to your trucK!!!
I am of the opinion that the best thing to have in inclement weather is COMMON SENSE!! You cannot make up for commonsense by buying any option or adding any aftermarket gadget to your truck. bottom line is that it doesnt matter what kind of vehicle you are in or how it is equipped, if you drive like an idiot, you will end up in the ditch or worse yet kill someone else
hope this helps
PS: if you read this far, i appriciate it.
Chad(North Carolina)
