http://www.spintechmufflers.com/spintech/index.asp
web site at http://homelink.jci.com. They responded via e-mail with the suggestions below. I only needed to do #1 and #4 and my range increased to about 150 feet.
1. Put a new battery in your hand-held remote. Training the HomeLink takes more power from the battery than when you push the button to open the door. Sometimes by putting a new battery in the hand-held remote, it does help pick up a better train and increases the range.
2. Retrain the HomeLink at different lengths and angles. Start by holding the hand-held transmitter 3-4 inches away then 5-6, even 6-8 inches from the buttons. Sometimes this helps pick up a better train to HomeLink.
3. Try a second remote with new batteries.
4. Straighten the antenna wire that hangs down from the garage door opener motorhead.
5. Park your vehicle outside of the garage during programming (make sure it is not under the garage door).
6. Try programming all 3 HomeLink buttons- they are all on different channels.
Here are the corrected instructions for turning the horn chirp on and off (the words in green/bold are the ones which need to be changed in the manual):
1. Place the key in ignition and turn the key to the ON position (donot start the engine).
2. Press and hold the LOCK button on the transmitter for four to ten seconds.
3. While the LOCK button is pressed, press the PANIC button on the transmitter and then release both buttons.
4. You will hear a single chime when programming is completed.
(To give credit where it's due, I must admit that I got these horn chirp instructions from an archived post on the DML.)
About two-thirds of the way through the instructions, the sentence in the manual which (incorrectly) says...
"Within thirty seconds, press and release the lock OR unlock button on all transmitters intended for use with this vehicle except the transmitter used to start the programming mode."
...should say...
"Within thirty seconds, press and release the lock AND unlock buttons SIMULTANEOUSLY on all transmitters intended for use with this vehicle except the transmitter used to start the programming mode."
(I figured this out myself the hard way after I accidentally deprogrammed one of my remotes while trying to discover the correct way to disable the horn chirp.)
I had the Farm Bureau just call the "source sequence" number into my dealer since time was short and they accepted that. I never got the $500 voucher to present to the dealer. I assume that the number is what they need to get their cash out of the deal.
2nddak
I got my dealer through autobytel and I was happy with their off of $500 over invoice, so there was no price negotiation. I ordered my truck, so I guess they had plenty of time for them to get the paperwork done.
I pressed the Lock button for 5 seconds, then pressed the Panic button for 1 second, and then released both buttons simultaneously. The chime then sounded almost immediately.
1. Use a heat gun or blow dryer to heat up the decal.
2. Use your fingernail to peel up one edge and then slowly pull the whole decal off. You may need to reheat the decal as you go. MOST of the adhesive should come off with the decal.
3. Soak part of a clean rag with WD-40 and use it to scrub off any remaining adhesive. (Others have suggested using 3M adhesive remover, but I figure most everybody has a can of WD-40 already and it works great.)
4. Wash and wax the newly exposed paint the same as the rest of your truck.
WARNING: Do NOT put WD-40 on the decal before you peel it off! I learned the hard way that this causes the decal to separate from the adhesive which leaves you with a LOT more adhesive to scrub off.
I was able to get them disabled pretty easily but have not been able to get them to start working again, at least with the instructions in my 2001 owners manual. I can't help but think that the manual is giving us the wrong procedure. Anybody out there know how to get it done?
There are a few items on this list which are specific to Dodge Ram problems, but most of the list is pretty generic and works just fine for the Dodge Dakota too. Happy Inspecting!
Are there any cupholders/storage space left when you order the 40/20/40 split bench in a Club Cab?
Yes you can. In fact, I have one (2001 QC)
Problem is, however, is that one of the cup holders is right behind the stickshift. If you have anything larger than a soda can in there, it will be crushed by the stick when you shift into 2nd or 4th gear.
A horrible design that Dodge should've corrected, but did not because most people do not get the manual trans.
You can sorta see pictures of it at my seat-mod page.
http://www.ayrow.com/seats.html
I noticed those arent power seats. Is there a way to adjust the tilt of the seat bottom without power 6-ways (stock Dakota 40/20/40 seats)? I have very long legs and thigh support is important to me, as I like taking long highway trips.
And again, are there any cupholders left when you order the bench seat? Also very important.
It is great reading from all you Dakota people. Looks like I may be joining your group.
bmwnomad
I'm not sure why your post (that I saw before) came back up again. I still don't understand the questions(s), so I'll do my best to answer.
No, the seats are not power. They can only be adjusted like normal seats with the exception that the driver's seat has a lumbar support adjustment.
As far as the bench seat is concerned, I have no idea since I never had the bench seat, nor do I have any intentions on intalling one. I had buckets and simply upgraded to leather buckets found in the Durango.
Again, if there is anyone out there that missed it, you can check it out here:
Hope this helps.
My 4x4, 4.7L V8, 5 spd, 3.55 axle, has a maximum tow rating of 4800 lbs if I remember correctly.
good luck
Bob
pound driver. You take this weight and deduct it from the 8,800 lbs. The remainder is the amount of allowable weight of the trailer and payload. In your particular case, given the figures as estimated by you, the payload is 5,200 lbs. Deducted from the GCWR of 8,800 lbs, it leaves 3600 lbs for the vehicle with driver. Unfortunately, I don't have any curb weight figures. A class III receiver from U-Haul or other provider will do just fine. Caution, never tow in overdrive.
Bookitty
Roger
The "horn chirp" instructions though, are incorrect. Where it says to "Press and hold the UNLOCK button on the transmitter for four to ten seconds" change UNLOCK to LOCK. Where it says "While the UNLOCK button is pressed, press the LOCK button on the transmitter and then release both buttons" change UNLOCK TO LOCK and LOCK to PANIC. Credit this to skylerk from his post of 14 Nov 00. Good luck!
To get the correct instructions, all you have to do is change step 2 so that the phrase "...ending in the ON position" instead says "...ending in the OFF position".
In case you don't want to go dig out your manual, here are the complete, corrected instructions which I have verified to work on my 2001 Dakota (the word in green/bold is the one which needs to be changed in the manual):
1. Close all of the doors.
2. Place the key in ignition and cycle the key from the OFF position to the ON position for a total of four times ending in the OFF position, do not start the engine.
3. Press the driver's side power door lock switch to lock the doors within 30 seconds.
4. You will hear a single chime when programming is completed and the automatic door locks feature will be deactivated.
5. To activate the feature again, follow the above steps again.
The system may be programmed to unlock all the doors, on the first press, using the following procedure:
2. Place the key in the ignition and turn the key between the OFF and ON position consecutively for a total of four times ending in the ON position (do not start the engine). The first three times you turn the key ON, you only need to wait for a single chime before turning the key OFF again. The fourth time you turn the key ON, wait for all six chimes to completely finish before proceeding to step 3.
3. Press the driver's side power door lock switch to unlock the doors and within 30 seconds to lock the doors.
Repeat steps 1 through 4 to reprogram the system to unlock only the driver's door on the first press.
I appreciate the info on the remote unlocking. However, it didn't work on my 01 Quad Sport 4X4. Wonder if anyone else has had any luck?
I tried every possible combination of your instructions and still one push opens all doors. Seems like some of these trucks might be set up different. By the way, I do NOT have the D/C security system. Maybe there's the difference???
fat_fenders
I have 2001 quad , its a week old now. mine was setup to open all 4 doors when you hit the unlock button. i just set it up to open the drivers door with 1 push & all 4 with the second push. in my owners manual, third edition, pg 16 is correct. all you need to do is disable the 4 door unlock mode !!! follow steps 1-6 on pg 16 & it will disable the system to work as you want it, i just did it myself !!!
good luck,
tom !!!!!!
1)Cold Air Induction System:
I understand Mopar has a system, what OEM offers the the best system and price, where on the WEB can I see that info and are these systems 50 state legal? Also, this does includ a 'supercharger' filter, right?
2)Performance Computer:
Same as above, Mopar offers one, where can I get a better price and maybe better performance
3)Cat-back exhaust:
I think Mopar makes one, looking at Gibson's Sport Truck Side Dual Exhaust, any other alternatives in the same price range with the same power increase, if not more.
4)Synthetic Oil/Mobil 1 Oil Filter:
Gonna try something called Purple ?
It advertises either 5 or 5% more HP, claims it is
a performance synthetic...thouhgts on best oil and filter?
Did I miss any 'cheap' mods to add, like a 180 degree thermostat (any real benefit to this or no issues with introducing problems to the engine mgmt system?)
With the above mods, a easy 250HP, 320 ft/lbs of torque is what I'm thinking, if not slightly more, possibly with a increase in gas mileage.
I just looked and discovered that I have the First Edition of the 2001 Owner's Manual -- so all of my previous posts about Owner's Manual corrections pertain only to the First Edition.
With all the grief I've been through trying to discover the reprogramming instructions by trial and error, I wonder if I can get Dodge to give me a "corrected" Third Edition manual to replace my inaccurate First Edition manual, or (probably) will they make me pay for it?
a large boat (too large) with my '95 Club cab without benefit of trailer brakes. I was however, very careful how I applied the brakes.
Bookitty
Happy towing.
robert
Today for the first time I had to pass several slow cars at one time. I punched the accelerator pretty hard and without realizing it I was approaching 100 MPH when all of a sudden the engine seemed to shut off. When I slowed down to 80 the engine was running again. This is the first time I pushed my truck up to that speed (accelerated to 100 MPH). Has anyone else experienced that same situation? Please advise.
George
Bookitty
Bookitty
I certainly agree with you. I am not one to constantly test either my or my vehicle's limits. I simply was not aware of these "limiters" and that they actually can govern a vehicle's speed. The point I was trying to make was that there are times that the extra horsepower and extra punch our trucks have can actually be safety factor when passing or trying to avoid a hazardous situation. Of course we all must use this power judiciously and with good judgement.
I agree that we all need to slow down in all aspects of life and not just on the highway. I just wish that all drivers would at least try their best to maintain the "posted" speed limits within 5mph either way. At least it would make commuting a little more pleasant. I must admit however, learning patience on my part is a skill I need to improve on.
Thanks for your kind words of wisdom Bookitty.
George
James
I have removed the offending append.
Jim H
