2022 Nissan Pathfinder Lease Deals and Prices
124678
  • MichaellMichaell Moderator Posts: 240,985
    NSanchez said:
    I'm looking for the MF/RV for SL trim level AWD zip code 10707
    Best rates for mile and month. I don't care too much as long as its at least 10K miles
    Please and thank you
    .00170 and 61%
    $2000 incentives
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
  • MomDealsNJMomDealsNJ Member Posts: 3
    MF, RV, & incentives for a 36/12 lease for a Pathfinder S, SL and SV in 07052.
    FWD or AWD?
  • marknmotionmarknmotion Member Posts: 20
    edited October 2021
    MF/RV and incentives for SV trim
    Fwd/awd
    zip code 90715
  • Royals_1969Royals_1969 Member Posts: 135
    Please may i have MF, RV, and incentives for a 2022 Pathfinder Platinum FWD
    24/12k miles zip 11572
    Royals
  • kyfdxkyfdx Moderator Posts: 236,760
    Fwd/awd
    zip code 90715
    AWD: .00190 MF and 72% residual. $2000 incentive
    FWD: .00140 MF and 68% residual
    Royals
    .00099 MF and 66% residual
    $2000 incentive
  • MinionMast3rMinionMast3r Member Posts: 2
    Can i please have MF, RV for 2022 Pathfinder SL 4WD for 36mo/12k and 36mo/15k at 92571. Thanks in advance!
    .00170 MF and 58% RV
    $2000 incentives
  • DKMD2022DKMD2022 Member Posts: 1
    edited October 2021
    Could I please get the MF, RV, and any incentives for the 4D Wagon Platinum 4WD in 07950? 36/15.
    .00150 MF and 57% RV
    $2000 incentives
  • purduealum91purduealum91 Member Posts: 285
    Please forward the MF, RV, and incentives for 24/15 or 36/15 S, SV, SL and Platinum in zip code 07960. Thank you so much.
    The above is AWD
    The above is AWD
    Plat: .00150 MF and 68%/57% residual
    S: .00209 MF and 73%/60%
    SV: .00170 MF and 69%/58%
    SL: .00190 MF and 71%/59%
    $2000 incentive
    FWD or AWD?
    AWD. Thanks
    FWD or AWD?
    AWD. Thanks
    S: .00209 MF and 61% residual
    SL: .00170 MF and 59% residual
    SV: .00190 MF and 60% residual
    $2000 incentive
  • miami305mvpmiami305mvp Member Posts: 16
    May I please request RV, MF, and any incentives for:
    SL trim with Premium Package
    FWD
    Thank you in advance.
    FWD
    .00120 MF and 55% residual
    Please forward the MF, RV, and incentives for November for 24/15 or 36/15 S, SV, SL and Platinum AWD in zip code 07960. Thank you so much.
    SL: .00170 MF and 69%/58%
    SV: .00190 MF and 71%/59%
    $2000 incentive
  • ebuccoebucco Member Posts: 11
    May I have the MF RV and Incentives for a Pathfinder SL AWD with Premium Package 24/10 and 36/10 in 10307.
    .00190 MF
    72%/61% residual
    $2000 incentive
  • r15mohdr15mohd Member Posts: 18
    what are the incentives specifically - lease cash? others?
    zip 33331
    zip 33331
    Just lease cash
  • gosoonersgosooners Member Posts: 44
    Can I have the MF and Residual for 2 options in ZIP code 77429
    - 2022 SL 36mo/12k 2WD
    - 2022 SL 36mo/12k AWD
    .00120 MF and 56% residual
    Thank you @kyfdx
    I'm going to the dealer to negotiate tomorrow. Can I also have residuals for the same options (both 2WD and AWD) for 10k mi/yr? I assume MF is still the same?
    Thank you @kyfdx
    +2% to go from 12K/yr to 10K/yr
  • frankofranko Member Posts: 1
    May I please have the MF, RV, and incentives for November for a 2022 Pathfinder Platinum AWD
    36/10 zip 43614
    36/10 zip 43614
    .00150 MF and 60% residual
    $1000 incentive
  • cdubbs89cdubbs89 Member Posts: 21
    May I have MF and residual for platinum awd 36/10 zip 11548
    $2000 incentive
  • ianky_CLTianky_CLT Member Posts: 1
    Can you please provide RV, MF, and any incentives for:
    S & SV trim
    FWD
    Thank You
    S & SV trim
    FWD
    Thank You
    S - .00160 and 58%
    SV - .00140 and 57%
    No incentives
  • ibmat94ibmat94 Member Posts: 27
    Hi, may I please have the MF, RV, and incentives for a 2022 Pathfinder SV and SL AWD 24/12 and 36/12 in 18954, thank you.
    SL
    .00170 MF
    70%/59% residual
    SV
    .00190 MF
    72%/60% residual
    $2000 incentive
  • joel282joel282 Member Posts: 22
    MF, Residual 36/15 SV & SL, AWD in 11763
    SL: .00170 MF and 58% residual
    SV: .00190 MF and 59% residual
    $2000 incentive
  • jkmachadojkmachado Member Posts: 17
    Hello. MF & Residual for SV FWD 36/12 in 33196 pls.
    .00140 MF and 57% residual
  • SprinklerSprinkler Member Posts: 34
    Can I get the MF and residual for a 2022 SL and Platinum, 36/12k, both AWD and 2WD in 91307. Any incentives? Thanks.
    FWD
    Plat: .00099 MF and 55% residual
    SL: .00120 MF and 56% residual
    AWD
    Plat: .00134 MF and 57% residual
    SL: .00153 MF and 58% residual
    $1500 incentive (except for SL FWD $0)
    Did December's MF and residual change for Awd Platinum 36/10 11548
    .00134 MF and 59% residual
    $1500 incentive
    Can I have the December MF and Residuals for 2 options in ZIP code 77429
    - 2022 SL 36mo/10k AWD
    .00153 MF
    60%
    58% residual
  • The_SheepdogThe_Sheepdog Member Posts: 96
    Could someone share the Money Factor (MF), Residual Value (RV) & any incentives that would be involved with the following car:
    2022 NISSAN PATHFINDER PLATINUM
    Lease Terms:
    36 Month's / 15K Miles
    Zip Code: 20855
    Thank you in advance!
    Lease Terms:
    Zip Code: 20855
    FWD or AWD?
    Lease Terms:
    Zip Code: 20855
    FWD or AWD?
    AWD please.
    Lease Terms:
    Zip Code: 20855
    FWD or AWD?
    AWD please.
    .00134 MF and 56% residual
