2022 Toyota Tundra Lease Deals and Prices
1356711
  • kyfdxkyfdx Moderator Posts: 236,527
    Good morning. Can I please have January's lease residual & money factor for a 2022 Tundra TRD Pro 4WD (36/10 & 24/10) in 06902? Thanks!
    I don't see any numbers for the Tundra TRD PRO for this month. Are they out, yet?
  • nyccarguynyccarguy Member Posts: 16,410
    Maybe not.
    2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
  • sneedo24sneedo24 Member Posts: 7
    Good afternoon. Do you happen to know Residual and money factor for a Tundra Platinum 4X4 5.5 Crew Cab 36/10? Zip 37312
  • MichaellMichaell Moderator Posts: 240,896
    .00235 MF and 74% residual
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
  • wantingadealwantingadeal Member Posts: 7
    Sorry in advance for so many questions. Could I please get the MF and RV for the following:
    SR and SR5 Crewmax 4x4
    24/12, 27/12, 36/10, 36/12, 39/12
    Zip Code: 40509
    Zip Code: 40509
    .00235 MF
    12K/yr
    SR: 85%/84%/79%/78% residual
    Subtract 2% for SR5
  • 2niCe2niCe Member Posts: 9
    2022 Toyota Tundra SR CrewMax with 5.5ft 4x4 - 36/10k
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 - 36/10k
    2022 Toyota Tundra Limited CrewMax with 5.5ft 4x4 - 36/10k
    Zip Code: 07731
    Thank you in advance.
    Zip Code: 07731
    .00235 MF
    80%
    78%
    76% residual
  • Mngo8888Mngo8888 Member Posts: 1
    2022 Tundra 1794 crewmax 4x4 full options with
    6.5 ft bed.
    36m/12k zipcode:91605
    Factor and RV please?
    6.5 ft bed.
    .00235 MF and 73% residual
  • Intelligent09Intelligent09 Member Posts: 4
    sr5 crewmax 36/10k
    Limited 36/10k
    4x4 and 4x2
    92782
    MF and residual & One pay residual if different.
    sr5 crewmax 36/10k
    Limited 36/10k
    4x4 and 4x2
    92782
    .00235 MF
    SR5 - 77% / 78% for 4x2/4x4
    LTD - 74% / 76%
    Deduct .00100 for one pay
  • Guatopo14Guatopo14 Member Posts: 3
    Hello, could I please get the MF and RV for the following:
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 - 36/12k
    2022 Toyota Tundra Platinum CrewMax with 5.5ft 4x4 - 36/12k
    Zip Code: 33544
    Zip Code: 33544
    .00175 MF
    73%
    66% residual
  • lucky932lucky932 Member Posts: 117
    edited January 2022
    Could I get the numbers for an SR5 Crew and Limited Crew 4x2 and 4x4
    24/12K
    36 or 39 (whichever is best) /12K
    in 77584?
    Thanks in advance and I appreciate the service you provide.
    24/12K
    in 77584?
    .00235 MF
    SR5 - 76% / 77% for 4x2 / 4x4
    LTD - 73% / 75%
  • Jimmackr3Jimmackr3 Member Posts: 13
    Could I get the numbers for an SR5 Crew and Limited Crew 4x4
    36/15K
    in 55129?
    36/15K
    in 55129?
    .00235 MF
    75% SR5
    73% LTD
  • jayjayb74jayjayb74 Member Posts: 15
    Hi could I get MF + RV on 2022 SR5 Crewcab 4WD TRD Off-Road package, 36/10 or 39/10, zip 97219 Thanks!
    .00235 MF
    78%/77% residual
    24/12K
    in 77584?
    .00235 MF
    LTD - 73% / 75%
    Thanks. Could I also have the numbers for the Platinum and 1794 trims. Looks like they are much easier to source. Also, Am I correct to assume there are no 24 Month terms at this time?
    lucky932 said:
    24/12K
    in 77584?
    .00235 MF
    LTD - 73% / 75%
    73% for either Plat or 1794 trims
    Add 6% to RV for 24/12 on any Tundra trim.
  • lstewielstewie Member Posts: 63
    Please
    SR5 DoubleCab 6.5 4WD
    SR5 CrewMax 5.5 4WD
    lstewie said:
    Please
    SR5 CrewMax 5.5 4WD
    .00235 MF
    78%/74% residual for Crew/Double
  • mmendoza2mmendoza2 Member Posts: 179
    What is the mf and residual % for a tundra limited (2wd) in south Fl (33027) for a 36/12 term.
    Are the numbers different on a trd off road (4x4)?
    Dealer tells me that a trd off road (4x4) is 73% while a limited 2wd is 68%.
    Is this accurate?
    Is this accurate?
    .00175 MF
    67% LTD 4x2
    I don't see a TRD Off Road trim for the Tundra.
    Sorry. It was an 4x4 sr5 with trd off-road package.
    If thats the case, do 4x4 tundras have higher residuals?
    What is the residual % for a 4x4 crewmax tundra?
    Is this accurate?
    .00175 MF
    67% LTD 4x2
    73% for 4x4 SR5
    71% for 4x4 LTD
    73% for 4x4 SR5
    71% for 4x4 LTD
  • Lance_ISFLance_ISF Member Posts: 45
    Could I please get the MF RV and Incentives for the following:
    2022 Toyota Tundra SR CrewMax with 5.5ft 4x4 - 24/10k
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 - 24/10k
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x2 - 24/10k
    2022 Toyota Tundra Limited CrewMax with 5.5ft 4x4 - 24/10k
    Zip Code: 94133
    Zip Code: 94133
    .00235 MF
    85%
    83%
    82%
    81% RV
  • bniblobniblo Member Posts: 7
    Can I please get the Residual and MF for an SR5 CrewMax 4x2 in 32966?
    24/10/12
    36/10/12
    24/10/12
    36/10/12
    .00175 MF and 72% RV
    No 24 month or 10K available
  • Hellp50014Hellp50014 Member Posts: 77
    edited January 2022
    Tundra 4x4
    Double Cab Limited
    SR5 CrewMax
    Rv mf 24/10 36/10 39/10
    60192
    Tundra 4x4
    Double Cab Limited
    SR5 CrewMax
    60192
    .00235 MF
    24/12 - 36/10
    LTD DBL: 78%/73% residual
    SR5 Crew: 83%/78% residual
  • jayt0583jayt0583 Member Posts: 4
    Limited crewmax 4x4 36/10k 24/12k
    Platinum crewmax 4x4 36/10k 24/12k
    MF and residual
    76542
    MF and residual
    76542
    .00235 MF
    75% / 81%
    73% / 79%
  • Eastoj11Eastoj11 Member Posts: 32
    2022 Toyota Tundra SR CrewMax with 5.5ft 4x4 - 36/12k
    2022 Toyota Tundra Limited CrewMax with 5.5ft 4x4 - 36/12k
    Zip Code: 53146
    Zip Code: 53146
    .00235 MF
    79%
    77%
    75% residual
  • sonora02sonora02 Member Posts: 209
    Can I please get the Residual and MF for 2022 Tundra Limited 4x4, 3.5L-T V6, 10-speed automatic
    transmission CrewMax, 5.5ft, Zip 92127, 36/12
    .00235 MF
    75% residual
  • Ketch785Ketch785 Member Posts: 11
    Can I get the residual and MRF for
    22 tundra platinum 4x4 crew max 5.5 bed
    36/12 zip 60031
    36/12 zip 60031
  • djpjrdjpjr Member Posts: 11
    Hello, looking for MF and Res for 1794 5.5 bed, 24/15 36/15
    Also what does the residual move to 18 and 20k a year? zip 06498 thank you
    .00235 MF
    77%/71% residual
    We don't have residuals for over 15K/yr
  • mjv_edmundsmjv_edmunds Member Posts: 3
    edited January 2022
    Sr5 crew max 4x4
    MF, residual, incentives in 60525
    36month 10k/yr
    Sr5 crew max 4x4
    36month 10k/yr
    .00235 MF and 78% residual
    Can I please get the Residual and MF for an SR5 CrewMax 4x4 5.5 FT in 32966?
    .00175 MF and 73% residual
    edited February 2022
    .00235 MF
    85%
    83%
    82%
    81% RV
    2022 Toyota Tundra SR CrewMax with 5.5ft 4x4 - 24/12k
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 - 24/12k
    2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x2 - 24/12k
    2022 Toyota Tundra Limited CrewMax with 5.5ft 4x4 - 24/12k
    2022 Toyota Tundra 1794 CrewMax With 5.5ft 4x4 - 24/12k
    Zip Code: 94133
    Just want to see if there any changes for the numbers for February.
