Much appreciated. Could I also get the numbers for the limited? Didn't realize option packages would get me what I want. ( 5.5' CrewMax 4x4, 36mo/12k for 97302)
Do those numbers normally change once a month?
Thanks again!
74% RV for the LTD trim.
Current programs run through 4/4.
2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
Can some one help with MF and RV on a 2022 Tundra Limited CrewMax 4x4 for 94578
36/12k
36/15k
48/12K
4815k
.00235 and 72%
Longer terms not supported
Hello! Looking for MF and RV for 2022 tundra crewmax, limited, 6.5’, 4x4, 44236.
30/15k
36/15k
78%
72% RV
.00175 MF and 73% residual
May I have the MF and Residual for the following in 98499.
2022 Toyota Tundra Limited CrewMax with 6.5ft 4x4 - 36/12k, 36/10k
.00235 MF and 74% residual
Can you please provide the MF and RV for a 2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 and Limited Crewmax with 5:5 4x4?
11355
76%
82% residual
Can I please get the MF and residual value for the following:
TOYOTA TUNDRA SR5 CREWMAX 4x2
36 / 12
76063
1794 crewmax 4x4
71% LTD
67% 1794
I believe the MF rates were good till 4/4 (tomorrow). Can you provide the new MF rate or should I inquire on 4/5?
2022 Toyota Tundra Limited CrewMax with 6.5ft 4x4 - 36/12k.
71%/67% residual for LTD/Plat
Limited CrewMax 5.5 4X4
Hello, could you please provide Res and MF for 4x4 Platinum 5.5 bed crewmax?
37312 zip
Thank you in advance!
98107 zip
Appreciate the help!
Dealers have the upper hand at the moment, in this tight market.
TIA!
MF and residual for a 22’ Tundra 1794 crew max 4X4, 6.5’, iforce max. 17331 zip, 36/10 and 48/10
.00235 MF and 73% residual
We don't have the 48 month terms
Can I get MF an RV for a 1794 and limited 5.5 36/10 36/12 zipcode: 13603? Thanks
.00175 MF
71% LTD
67% 1794
.00175 MF
67%, 71%, 74% residual
Correction to previous answer
Double Cab
Limited: .00175 MF and 67% residual
There is no 1794 double cab
Please and thank you
SR5 Crewmax: 74% residual
.00235 MF
70% residual
For the longbed, the RV is 75%
Can I get the 36/12 as well please
