2022 Toyota Tundra Lease Deals and Prices
15791011
  • amsmith83amsmith83 Member Posts: 17
    Can I please get MF and RV for a 2022 Tundra SR5 CrewMax 5.5 4X2, 36/10K in 77498?
    TI
  • MichaellMichaell Moderator Posts: 241,289
    TI
    .00235 MF and 75% RV
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
  • statsloverstatslover Member Posts: 12
    Can I please have the RV and MF for 2022 Tundra Capstone in 55902? 36/12
    edited June 2022
    I don't see a Capstone trim.
    Is this a package on another trim?
    Also, provide cab style and 2WD or 4WD.
    edited June 2022
    Capstone are all crewmax, 4wd, hybrid, 5.5ft bed. Not an option, but Capstone is a new trim.
  • kyfdxkyfdx Moderator Posts: 237,130
    .00235 MF and 65% residual
  • joshacct1986joshacct1986 Member Posts: 5
    2022 Tundra Platinum CrewMax 5.5 4WD
    10k/36 mo
    10k/39 mo (if available)
    68022
    10k/36 mo
    68022
    .00235 MF and 72% residual
  • Recon786Recon786 Member Posts: 11
    Can I get MF and Residual for Limited 4x2 Crew Max 5.5 in 92880 please? John Elway's Toyota Riverside today told me 80% RV, I want to confirm.
    The only 4x2 model of the Tundra with an 80% residual is the SR5 (for 24/12)
    Limited is 77%
    Dealer cannot alter the residual; it's fixed by the bank.
    MF is .00235 for all trim levels.
  • wangstarr03wangstarr03 Member Posts: 12
    edited June 2022
    Looking for MF & residual in zip 20874 & 23227 for 36/15:
    - 1794 4x4 5.5 (non-hybrid)
    - TRD Pro
    Any incentives available? Thanks!
    - TRD Pro
    .00235 MF
    69% 1794
    71% TRD Pro
    Limited is 77%
    Ok thanks!
    Limited is 77% for 36/12?
    Limited is 77%
    Ok thanks!
    77% for 24/12
  • johnciv6johnciv6 Member Posts: 67
    Im interested In:
    sr5, limited, platinum
    5.5 or 6.5 crewmax
    4x4
    84532 is in utah is it different in colorado? 81501
    Thank you so much
    johnciv6 said:
    Im interested In:
    5.5 or 6.5 crewmax
    4x4
    Thank you so much
    .00235 MF
    76%, 74%, 72%
    Either bed size
    Same numbers for CO and UT
  • jetbilljetbill Member Posts: 8
    Can you provide :
    5.5 or 6.5 crewmax
    4x4 and 4x2
    34639
    jetbill said:
    Can you provide :
    5.5 or 6.5 crewmax
    4x4 and 4x2
    34639
    .00175 MF
    2WD: 72%, 67%, 64% residual
    4WD: 73%, 70%, 66% residual
  • Crawfojj44Crawfojj44 Member Posts: 17
    Hello, could I please get residual and mf for 2022 Tundra SR5 double cab 4x4 6.5 bed for 24 months and 36 months (10k miles per year) for 14760. Thank you!
    .00235 MF
    76% 24/12
    71% 36/10
  • Josh_Twins2018Josh_Twins2018 Member Posts: 2
    edited June 2022
    Could I get residual and MF for 2022 Tundra SR5, Crewmax, 4x4, Short Bed 5.5' TRD Off-Road if that matters. Zip is 29150. 36 month and 10k miles.
    .00175 MF and 73% residual
    No 10K allowance for the SouthEast region.
  • MTTMTT Member Posts: 17
    edited June 2022
    2022 Toyota Tundra SR5 4D CrewMax 4x4
    MF & Residual
    10k/36 months
    Zip: 11596
    MF & Residual
    10k/36 months
    Zip: 11596
    .00235 MF and 76% residual
  • Tgrubbs112Tgrubbs112 Member Posts: 7
    2022 Toyota Tundra, 1794 Edition. 5.5 foot bed. TRD off road package
    Looking for MF & Residual on 10k/36 Months
    Zip: 46077
    Zip: 46077
    2WD or 4WD
    4wd
    Zip: 46077
  • mb9182mb9182 Member Posts: 31
    Zip code 07733. Tundra Limited Crewmax 4x4, Hybrid.
    MF and residual for 36mo/15k
    Thanks in advance
    Thanks in advance
    .00235 MF and 70% RV
  • cheapdad0000cheapdad0000 Member Posts: 172
    edited June 2022
    Can I please get MF/RV for a Tundra 4WD Crewmax and Double Cab SR5 for 36/15 in 27519? Thanks.
    Crew: .00175 MF and 71% residual
    Double: .00175 MF and 69% residual
  • hillcrghillcrg Member Posts: 10
    I am looking for the MF, Residual Value, and incentives on a SR5 Crewmax 4x4 in zip code 32223 on a 36/10 or 36/12 - thanks!
  • variable31variable31 Member Posts: 28
    MF RV incentives(?) for SR 4x4 in 77573? 36/12 & 24/12
    Double or Crew cab?
    Crew cab please
    Crew cab please
    .00235 MF
    83% / 77% for 24/36 and 12K
  • JbbasticJbbastic Member Posts: 11
    Can i get mf/rv please for below. Thanks!
    Sr5 crew cab
    4x2
    Sorry, revised
    Sr5 crew cab
    4x2
    5.5 bed
    28226
    Jbbastic said:
    Sorry, revised
    Sr5 crew cab
    4x2
    5.5 bed
    28226
    .00175 MF and 72% RV
    Any July mf/rv yet for below?
    Sr5 crew cab
    4x2
    36/12 or 36/10 if offered
    5.5 bed
    28226
  • seanmwelshseanmwelsh Member Posts: 37
    Looking for mf/Rv for the SR5 and Limited trims. 61111 zip code and Wisconsin. 4x4. 36/10K
    TIA!!!
    Can I please have the MF and RV for SR V6 double cab 4x2, 36/10, 77498
    Any change for July on this?
    2022 Toyota Tundra, 1794 Edition. 5.5 foot bed. TRD off road package 4WD
    Zip: 46077
    TIA!!!
    Crew or Double Cab?
    Standard MF and 70%
    The Standard rate has been .00235, but I don't yet have the July numbers to confirm
    Zip: 46077
    Standard MF and 71%
    The rate has been .00235 for a while, but don't yet have the July numbers to confirm.
  • b_hart12b_hart12 Member Posts: 31
    Hello could I please get MF, Residual, and Incentives for Platinum Crew Max 5.5 ft 4x4 and TRD Pro for 36/12 in 41048. Thanks
    Crew or Double Cab?
    Crew cab
