2023 Jeep Grand Cherokee Lease Deals and Prices
MichaellMichaell Moderator Posts: 267,794
edited July 2022 in Jeep
Ask your 2023 Grand Cherokee lease questions here! Get information on money factors, residuals, incentives, deals, payments and prices.
When making a request for lease information, please include the following information for the quickest response - body style, cab style (for trucks), trim level, RWD/FWD/AWD/4x2/4x4 (as appropriate), lease term, mileage allowance and your location.
«13456767
  • Pperc15Pperc15 Member Posts: 46
    Are the 2023 JGC L program numbers now available?
  • MichaellMichaell Moderator Posts: 267,794
    Yes
    Yes
    Finally! Can I please have the MF and RV and any incentives for a 2023 JGC L, Limited trim, 4x4, 36mo, 10k? Also, any differences for the Overland trim? 19035.
  • kyfdxkyfdx Moderator Posts: 271,312
    Pperc15 said:
    Yes
    Standard MF
    62%/58% residual for LTD/OVL
    Pperc15 said:
    Yes
    Standard MF
    0.00148 ?
    Pperc15 said:
    Pperc15 said:
    Yes
    Standard MF
    0.00148 ?
    .00168 for 36 months
  • stealyourface93stealyourface93 Member Posts: 4
    I'm considering placing an order for a 2023 Grand Cherokee 4xe (base trim, 36/10k). I am hesitating because I'm told the order will take ~4 months to build and I don't know where MFs will be in the late November timeframe.
    Understand that no one wants to speculate, but if you could shed some light on how MFs have trended over the last 4 months, perhaps that would drive some insight on where they're headed over the next 4 months? If I do order, should I be prepared to lease at +1% APR vs. today, or would CCAP potentially cushion some of the inputs to support volume? Any guidance would be very much appreciated
    Go back to the 2022 thread and review the historical numbers.
    But, past performance is no indicator of future results.
    In other words, we have no clue what the programs will be like at the end of the year.
  • ATwrangler55ATwrangler55 Member Posts: 50
    Evening! Looking for GC L Laredo and limited 4x4 in 04401 10/24 10/36
    Standard MF
    79%, 75% - 24/10
    65%, 62% - 36/10
    edited July 2022
    Standard MF
    79%, 75% - 24/10
    65%, 62% - 36/10
    Thanks! Do you know what the standard mf is for 24 and 36 mo? Also does 39 months change residual?
    Standard MF
    79%, 75% - 24/10
    65%, 62% - 36/10
    63%, 60% for 39/10
    MF
    24 - .00331
    36 - .00168
    39 - .00164
  • nickyS_713nickyS_713 Member Posts: 54
    Hi can you please provide MF, Residual, and any incentives for 2023 Grand Cherokee L Altitude 4WD in 10804. Thanks.
    Standard MF
    64%
    62% residual
    No incentive info
  • LoGiKLoGiK Member Posts: 97
    Can I please have MF, RV, and Incentives for the following:
    2023 Jeep Grand Cherokee L - Altitude - 4x4
    2023 Jeep Grand Cherokee L - Limited - 4x4
    Terms:
    36/10k
    39/10k
    Zip: 33016
    Terms:
    36/10k
    39/10k
    Zip: 33016
    Standard MF
    ALT - 65%, 63%
    LTD - 62%, 60%
    No incentive info
  • gohawks78gohawks78 Member Posts: 40
    Can I please have RV and MF for 2023 Grand Cherokee (2 row) 4x4 in Summit trim? Zip is 60174, 36/12. Thanks
    Standard MF
    58% RV
  • lespaul30lespaul30 Member Posts: 70
    Could I get the MF, RV, and any incentives for the 4xe Overland trim? It would be 36/12 in 79119 zip code. Thanks!
    No 2023 GC 4xe numbers, this month.
  • BEEMERXBEEMERX Member Posts: 43
    Hi, may I please have numbers for
    2023 Grand Cherokee L Altitude trim
    36 months 10k miles, 07726.
    Standard MF and 65% residual
    Can I please have MF, RV, and Incentives for:
    2023 Grand Cherokee L - Altitude - 4x4
    2023 Grand Cherokee L - Altitude - 4x2
    2023 Grand Cherokee L - Limited - 4x4
    2023 Grand Cherokee L - Limited - 4x2
    Zip: 33016
    Terms: 36/10k
    Zip: 33016
    Terms: 36/10k
    No incentive info
    For all..
    Zip: 33016
    Terms: 36/10k
    No incentive info
    For all..
    Thank you. The RV is the same for the Limited?
    Zip: 33016
    Terms: 36/10k
    No incentive info
    For all..
    For all requested trims.
  • STISeanSTISean Member Posts: 7
    Any lease figures yet on the GC 4xe?
    Not on the 2023 model
    Can I please have RV and MF for 2023 Grand Cherokee (2 row) 4x4 in Overland trim? Zip is 60174, 36/12. Thanks
    Standard MF and 58% residual
    Thank you, what is the standard MF for 36?
    .00186 MF
  • drewpde23drewpde23 Member Posts: 22
    edited August 2022
    Hi, I would like know to the MF/RV for a 2023 Grand Cherokee Summit & Summit Reserve (two row) for 36/12000 as well as any rebates in 26508 for August 2022 please.
    No incentive info
    Either trim
  • daveptllcdaveptllc Member Posts: 18
    Please provide MF, RV and Incentives for zip code 85260 36/10 K for
    1. Jeep Grand Cherokee 4xe (base model)
    2. Jeep Grand Cherokee Limited 4x2 WL (new design, 2 row)
    1) No info on the 4XE
    2) Standard MF and 62% residual
    No incentive info
  • joe1896joe1896 Member Posts: 35
    Hello. Looking for August 2022 MF, RV, incentives on a 36/10k lease for the following in zip 11803:
    2023 Grand Cherokee WL Laredo L 4x4 (3-row)
    I suspect no word yet on Sept. figures? Presume no, but wanted to avoid a check back in a few days, if possible. Thanks very much
    No info
    New programs start on September 7th
    No info
    Understood, and will check back in. Thank you.
  • miguellozamiguelloza Member Posts: 45
    Hi can you please provide MF, Residual, and any incentives for 2023 Grand Cherokee L in 90604.
    Overland 4WD
    Summit 4WD
    Overland 4WD
    Summit 4WD
    Standard MF
    57% residual
    Both trims
  • MickeyMCOMickeyMCO Member Posts: 34
    2 row for all.
    Sorry
    Hello Michaell,
    May I ask you to please provide me with the lease info on the following vehicles:
    1. 2022-2023 Overland 4X4
    2. 202-2023 Summit 4x4
    3. 2022-2023 Summit Reserve 4x4
    Zip code: 68516
    Terms/mileage
    39/12
    39/15
    Rate: what is the standard MF ?
    Question: Will Sept 2022 have incentives (end of quarter?) better rates?
    MickeyMCO said:
    2 row for all.
    Sorry
    Hello Michaell,
    Zip code: 68516
    Terms/mileage
    39/12
    39/15
    2023
    39/15
    Standard MF and 54% residual
    All three trims
    39 mo = .00182 MF
    Current programs run through next Tuesday.
  • craigrod9craigrod9 Member Posts: 14
    edited September 2022
    2023 JGC Limited 4x4 (2-row) - 10k / 36 & 10k / 24 - MF, RV, & Incentives for 92656.
    Standard MF
    77% / 63% RV for 24/36 and 10K
    Hi, may I please have numbers for 2023 Grand Cherokee L Altitude trim
    36 months 10k miles, 07726; if anything changed from August?
    September programs will be released tomorrow; ask again then.
    2WD or 4WD?
    2WD or 4WD?
    4WD, sorry
