2023 Chevrolet Silverado Lease Deals and Prices
13468914
  • MichaellMichaell Moderator Posts: 267,638
    Could you tell me the residual/MF on a 1500 4WD RST crew on a 36/12 for zip code 28602
    Thanks in advance
    .00153 MF and 62% residual
  • hsvnolehsvnole Member Posts: 76
    Could I get the May MF/residual on a 2023 Silverado 1500 4WD LT with 2.7L for zip code 35806?
    1) 24/10
    2) 36/12
    1) 24/10
    2) 36/12
    1LT or 2FL?
  • zain224zain224 Member Posts: 8
    edited May 2023
    Can I get a residual, MF and incentives/ rebates on 2.7L 2023 Silverado 1500 LT 1LT and on 2.7L 2023 Silverado 1500 RST 1SP? Both are short box crew cab and 2WD.
    36/15K miles. Zip code is 77095.
    LT - .00153 and 60%; $1000 incentives
    RST - .00153 and 60%; no incentives
  • Randy_MacHaikChevyRandy_MacHaikChevy Member Posts: 17
    edited May 2023
    2.7' TurboMax Silverados all have 1000 CCR, Including RST and TrailBoss Custom-
    All Trims except for 2FL and 1CX are the same on residual and MF
    36 Mo/
    15k Mi 60% -
    10k Mi 63%
    All eligible rebates below- Employment Rebates are not stackable- including Military and Student
  • BostonOne617BostonOne617 Member Posts: 6
    Hello Could someone please tell me the MF, RV, and incentives for 2023 Trailboss LT 02184 36/12K lease ?Thank you.
    .00222 MF and 64% RV
    $1000 incentive for the 2.7T engine only
    Thank you. What about 10k/yr?
  • kyfdxkyfdx Moderator Posts: 271,029
    65% residual
    Thank you. Could you please tell me the MF, RV and if there are any incentives for 10k/ 36 12k /36 are for a 1500 LT 02184 ? Would they be the safe or different for different trim? Thank you.
    Double or Crew Cab?
    If it's Crew Cab, 1LT or 2FL?
    Crew 1lt
    Crew 1lt
    Custom or Custom TrailBoss is .00234 MF and 66% residual. That seems to be the best combo, even though the MF is higher.
  • Aguiar91Aguiar91 Member Posts: 5
    Can you please tell me the MF, RV and incentives for a 36/12K on a Silverado 1500 High Country RWD in 33157 Miami?
    .00139 MF and 62% residual
  • gscottyggscottyg Member Posts: 40
    MF and RV for
    2022 silverado custom rwd 2.7
    2023 silverado custom rwd 2.7
    36/12k and 39/12k
    zip 34238
    gscottyg said:
    MF and RV for
    36/12k and 39/12k
    zip 34238
    Which cab style?
    2022 Silverado discussion
  • hlabbashlabbas Member Posts: 5
    Hello, could i have the MF and RV on the following: 2023 CHEVROLET SILVERADO 1500
    Double Cab Standard Box 4-Wheel Drive LT 2FL?
    Zip code: 48067
    Zip code: 48067
    .00197 MF and 68% residual
    .00246 MF and 74% residual
    $1500 customer incentive
  • GaryG96GaryG96 Member Posts: 3
    Hello!
    Can I have RV and MF for the 2023 Chevy Silverado 1LT 2.7L Turbo, Crew Cab, Standard Bed, 4WD for 36/10 in 95928.
    GaryG96 said:
    Hello!
    .00153 MF and 63% residual
    $1000 customer incentive
    MF and RV for
    36/12k and 39/12k
    zip 34238
    crew cab
    gscottyg said:
    MF and RV for
    36/12k and 39/12k
    zip 34238
    crew cab
    Crew or Double cab?
    Post 2022 model questions at this link
    crew cab
    gscottyg said:
    MF and RV for
    36/12k and 39/12k
    zip 34238
    crew cab
    gscottyg said:
    crew cab
    .00234 MF
    66% / 64% RV
    $1000 incentive
  • TheMonkeyPicklerTheMonkeyPickler Member Posts: 10
    Can i get numbers for a 2023 crew cab rst short box 4x4 for 15k/36. 13905
    .00153 MF and 60% residual
  • russ120712russ120712 Member Posts: 16
    Can I please have the RV, MF on a 23 Silverado crew cab 2lf and a custom
    Zip 11735
    3yr/10k or 3yr 12k
    Zip 11735
    3yr/10k or 3yr 12k
    .00205 and 69%
    $1000 incentive
    @Michaell can you supply 36/10 as well for the custom Silverado.
    Thanks in advance
    Thanks in advance
    +1%
    Does that mean 68% or 79%
    69% + 1% = 70%
    edited May 2023
    Thank you sir
    Was a typo! Meant 68% or 70%! Thanks.
  • Kimble19989Kimble19989 Member Posts: 3
    Can I get RV and MF for 2023 Chevy Silverado ZR2. 36/12 and 36/10 for 13901
    .00180 MF and 63% residual
  • ray_rezray_rez Member Posts: 42
    May I have the MF, Residual and incentive for Chevy Silverado
    CREW CAB, STANDARD BED, HIGH COUNTRY, 4WD 5.3L ECOTEC3 V8
    36/10k
    Zip code 77494
    36/10k
    Zip code 77494
    .00139 and 63%
  • bryanwilson1bryanwilson1 Member Posts: 42
    edited May 2023
    Can I get the Mf,RV and any incentives for 44870 please
    Crew cab, 3.0 dirtymax, 4x4 and max trailering.
    RST vs. 1LT
    Thanks again for all you do
    RST vs. 1LT
    .00153 MF and 63% RV
    Either trim
    Can I get mf, residual, 36/12 on a custom 2023 crew cab 4wd zip code 11729
  • screen_namelscreen_namel Member Posts: 17
    Could I please get May numbers MF, RV & incentives for zip 99037? Term 36/12
    • 2023-Silverado 1500 crew cab LTZ 4WD
    .00180 and 63%
  • zapat2f7zapat2f7 Member Posts: 40
    MF and Res
    2023 Silverado Custom
    zapat2f7 said:
    MF and Res
    Double or Crew Cab?
    4x2 or 4x4?
    Which engine?
    @zapat2f7 said:
    Double or Crew Cab?
    4x2 or 4x4?
    Which engine?
    4x2
    Sorry 4x2 4 cyl turbo
    @zapat2f7 said:
    @zapat2f7 said:
    Double or Crew Cab?
    4x2 or 4x4?
    Which engine?
    4x2
    And double cab.
    Sorry I’m slow this morning.
    4x2, double cab, 4cyl turbo
  • JoeboyJoeboy Member Posts: 1
    MF and Res
    2023 Silverado lt 4wd crew cab
