92 Octane Vs. 89 Octane...big difference?
Does anyone know what the big difference is
between 89 and 92 octaine...I just purchased a new
bmw 328ci and all over the owners manual it says to
use only premium gas, is there a big difference in
quality?
quality?
By the way, there are a lot of other people around who's cars require 87, but they are burning higher octane gas thinking it will improve their performance. Most of them are wasting their money. If your car requires 87 and you are not having pinging or knocking problems, there is no benefit to burning 89 or 92 octane gas.
Also, at higher elevations you may notice that the gas pumps are labelled with lower octane numbers. That's ok, because with the thinner air at those elevations, lower octane numbers work well.
I
Sorry for asking . I'm new to cars.
Bruce
Today's cars have knock senors that adjust the lean/rich to the type of gas your running. No need to waste money if your engine does not knock.
I did find that I got better mileage from Shell gas than others. A gasoline buyer friend of mine confirmed this. Shell just has more energy (BTU) per gallon than other gasolines. They refine their own gas while other buy it from the same terminal and add their own additive to make it "special". But at the root it's all the same stuff.
difference,is there going to be engine damage such
as deposits build up that cause noticeable pinging
after miles pile up.I also have heard that you should run a can of injector cleaner through once a month.Is chevron with techron a cleaner,Would I have the same effect by using chevron once a month?
Your host, Bruce
knocking and pinging are both used to describe detonation, where the fuel mixture is too lean or the ignition timing to advanced. it results in very high cylinder pressures because it's an explosion, whereas normal combustion is burning.
it often sounds like firecrackers. you should then be getting off the gas in a hurry, knock sensor or no.
the other common problem is pre-ignition, also known as dieseling. in a gasoline engine, it should cease to fire after the ignition is cut.
it sounds like a diesel.
-Colin
PS, regarding fuel... start with the mfg recommendations and experiment if you're curious or experience sluggish performance or bad gas mileage. (both of which can happen from too low or too high octane.) You will need at least 2-3 tankfuls of the "new" octane before your ECU figures it out, one tankful probably will not be enough.
Was it a waste of money? From what I'm reading at this website, it sounds like it was and maybe my experiences using lower octane were only coincidental and definitely not scientific. Wish I knew the answer...
I just bought a '99 Camry LE 4cyl so I'm looking in the Owner's Manual and it states for my type engine (5S-FE):
OCTANE RATING: Select Octane Rating 87 (Research Octane Number 91) or higher.
(It goes on to say that the 6cyl (1MZ-FE) engine runs on 87 but that for improved vehicle performance 91 or higher is recommended.)
Don't know yet, since I'm still running on the dealer's tank of gas but I'll probably opt for
mid-range octane like 89, till I do further research and possibly, but no guarantee here, my wife notwithstanding.
