deteriorating gas mileage
Is it normal for a vehicle's gas mileage to
deteriorate as the car gets older and a lot of
miles put on it? When new, my 90 nissan pathfinder
used to go almost 300 miles on a tank of gas (15
gal. tank, so about 20 MPG, mostly freeway
driving), but now it has 135K miles, and I'm lucky
if I get even 250 miles (approx. 16.6 mpg) on a
tank. A few days ago I was very surprised when I
had driven only 100 freeway miles and the tank was
already half empty! My driving conditions, tire
inflation, maintenance patterns have stayed the
same. Is notable gas mileage deterioration just
part of the natural wear on the engine, or is there
something wrong?
something wrong?
86 ply. rel. with 141k miles.
I got worse mileage when they brought out the oxygenated gas. The mileage will vary between different brands of gas as well.
A full tune-up might help.
Was the oxygen sensor ever replaced? I did this and got better mileage again.
1) have your driving habits drastically changed? (i.e. new job location, etc.)
2) change your fuel filter
3) clean your fuel injectors
4) what do you mean "you gave it a tuneup"? changed plugs/wires, etc., but didn't change fuel filter?
more info needed...
-Chris
-Chris
1) when was the last time you had a tune-up?
2) when was the last time you changed the air filter and fuel filter?
3) if 1 and 2 are fairly recently, take it to the dealer (or otherwise competent mechanic) and have them read the dme codes and see if something has failed.
you shouldn't lose 50% of your fuel mileage.
there's another possibility here too. how do you drive? does the right foot go all the way to the floor every time you leave a light or stop sign? merely changing the way you accelerate can have a huge difference in your mpg.
-Chris
A sudden drop as sempai notes, or low milage on a recent purchase as krintine9 notes (why it was traded?) may be the result of a worn timing belt jumping one tooth. Have your mechanic remove the cover and check the marks. A worn belt on some cars may cause major engine damage if it jumps too many teeth.
Harry
too much gas! i get around 12 - 13 mpg. is there
anything i can do to fix this? are there parts to
service? or is it the timimg? the car has only 15k
miles. what should i do
-Chris
