Because of the earlier problem with the turn signal, I am guessing that the switch might be faulty. I did some research online, and many others reported similar problems with their Mazdas where their taillights and dashboard lights would stop working. Any ideas what the reason might be?
backy, "Mazda 626 Troubles" #2073, 2 Jun 2006 4:05 pm
Mike
Anybody on this board have any advice/experience on what kind of bill I'm looking at? I'm in the Dallas area so if anybody can recommend any local shop here I'd appreciate it.
Any other advice/comments would be highly appreciated.
No codes in memory.
thanks in advance,
firefighterfox
Does it still pull to the right on accell and then left on letup?
I ask because I have a similar problem with 2 of my vehicles and have heard it can be caused by worn motor mounts.
Is the antenna back there? I wonder if that is the cause. I have so many problems I am working on right now that it is a low priority at the moment. (The car is in my garage and safe from more rain too.)
Any help or guidance would be apprectiated.
Did you fix it ? How?
I just bought this car and im noticing already that it having problems. (1) If i leave the car off for a while, let say overnight, it turns on fine. but when i park and and come back let say for like 20 mins or so, the car cuts off!!! (2) When it idle, it vibrates and makes this weird sound now and again. i can't explain it. Like its about to turn off and then it pick up again... (i hope ya can understand this)
Any input. PLEASE!!!!
You might also use "keyword search" on the left for "technical questions" or "no start"---these are pretty active topics and can cover all sorts of cars.
You need to make sure that the car is parked level when you check the oil level because you can get really erroneous readings when the car is parked even on a very mild incline. BTW, it takes 4 quarts of oil to refill the crankcase (with a new filter).
Mine was hit a couple of times and the body work repair was not up to spec. I plan on driving it until it dies and I get hit with a repair that makes sense to say I'm better off putting the money into a new vehicle.
Thanks/Vashtie
My '97 has 170,000 trouble free miles. A shame that you happened to have purchased a vehicle with that problem.
