Saturn Maintenance & Repair
continental should have some mileage guarentee and provide pro-rating of the tires. At 29K, you didn't get 1/2 the mileage of the tires.
roads are sloped to the sides and your vehicle should naturally drift to the side, but at a very slow rate if it's aligned properly. don't ask me how long, but several seconds.
you shouldn't have to fight the wheel with excessive force to get it to track straight down the road. if you let go of the wheel and move quickly towards the side, you have a problem.
winds can affect a vehicle, honestly they can. tire tread pattern and road surface, specially groves in the road or going over a metal grate bridge together can cause you to move all over as well. but both of these phenomenon are situation dependant and short lived.
if you have to use excessive force to turn right or left, or you don't have to use much force at all, your tires may be under or over-inflated respectively. the former usually is indicated by wear on the sides of the tread but not in the middle, while the latter (over-inflation), you'll have wear in the middle of the tires but not the sides.
these may help:
http://aa1car.com/library/wheel_alignment.htm
http://aa1car.com/library/tire_wear.htm
Thanks!!
Thanks again!!
Anyway it's an easy thing to try cheaply you just need to take the time to bring the car to a saturn dealership.
Good luck!
But the problems are beginning to take their toll. And while I am probably going to get a new vehicle soon (considering either an 07 or 08 VUE to accommodate growing family, but skeptical of the Hybrid), I would still like to get as much out of my current Saturn as possible.
Problem: Several times over the last three years I have taken the car to the dearlership because the engine will begin racing for no particular reason. I can be idling and the tachometer will suddenly soar to over 2,000 rpm.
When I'm decelerating, the rpm will jump when I'm at about 35 mph.
Every time, I am told there is a faulty sensor or some other minor thing. The repair bills are relatively low, which isn't the problem. I'm just getting tired of having to take the vehicle in for this.
Any idea what is going on?
This particular problem is annoying, but not as bad as the $762 repair bill I just endured ... :mad:
I have 24,000 miles on the '07, also a 4-cylinder, 5-speed, front wheel drive model. This week the clutch was replaced due to a factory parts mismatch problem identified by the dealer via a factory service bulletin. It was accomplished in under 24 hours and I was given a free rental car while repairs were made.
The '07 is a more refined vehicle in every way. It's the same dimensions, same basic utility and features. But the drive train, suspension, sound control, brakes - all are somewhat improved vs. the '02. For the price, I think the Vue is a great value. I currently average 28 mpg highway.
So here's the problem, the wipers work fine on low and high speeds. If I try to use them on the delay setting, they will go up but struggle to come back down. The same thing happens if I try to use the mist setting. I was told that it might be the motor but it sounds more like the switch on the steering column to me. Any ideas???
Me personally? I'd be looking for another dealership. At the very least, they should do it at cost.
I bought a new horn (the one with the two mounting sites). However, my Saturn horn has a three-wire relay cap. I cut that off (per seller at AutoZone) and have tried "wrapping" each wire on one mount while the other is attached to a cable that is attached to the grounded horn. Nothing works.
:confuse: QUESTION: WHAT AM I SUPPOSED TO DO!?!?!? How can I get this work!?!? PLEASE HELP ASAP!!!!
I am not a mechanic by any means -- and have no clue as to how to make the horn your purhcased work -- but I feel I can point you in the right direction. After diagnosing and correcting it a few times, the meachanics at the garage I go to put in a new Clock Spring. Hopefully this is different than a horn, though like I said -- this is why I go to professionals!!
What I did in the meantime was took the fuse out so the horn wouldn't work, as it would go off in the middle of the night and the neighbors would get upset.
Hopefully this helps a little bit -- please let me know.
A fellow Saturn owner, ~ MATT
Any help would be much appreciated.
