Pontiac Bonneville General Maintenance and Repair
1202123252644
    mfahey1mfahey1 Member Posts: 419
    Alaskanhotrod, might I ask what your system cost and what differences you've noticed with it on?
    Just a reminder to people about leaves and things collecting in the bottom of the front fenders just in front of the door.
    This was an issue with the earlier models(pre-2000) and I would have assumed that GM would have fixed it in the redesign in 2000. However, when you open your door, look down at the bottom of the fender and if your car spends any time at all outside, you may see a collection of stuff just sitting there waiting to get wet after the next rain or car wash. The best way to clean it out is to blow it out with compressed air or lacking that, a hose.
    skyhawk3skyhawk3 Member Posts: 42
    Looking for help. 2001 SLE with 36,800 miles. Today noticed loud noise from dashboard. Starts at 35 mph and increases in volume up to 70 mph. Reving the engine in neutral does not produce the sound. It reminds me of a baseball card in the front wheel of a bicycle. I shut the cabin cooling system off and the noise continued. I drove into a big empty parking lot and shut the engine off in neutral. The noise continued until I coasted under 35 mph. I looked at and felt the original equipment Eagle tires and they were all fairly cool to the touch.
    Thank you for any suggestions.
    Ed
    theicemantheiceman Member Posts: 736
    And beyond 70 mph? (just kidding...)
    You're sure it's from the dashboard? I had a similar experience in our Camry years ago - turned out to be a worn speedo cable. Not an expensive repair - hope yours turns out to be that simple.
    ice
    ayratayrat Member Posts: 26
    the problem seemed to be missing ground between electronic ignition module aluminium sole and aluminium mounting bracket. Cleaned them up put everything back and it started...Thanks God--
    avoided changing parts and mechanics screwing up with the car...
    Still do not know what 58 meant though.
    The problem was defective right front bearings and hub. My wife has her "Bonnie" back.
    Ed
    That's the problem with front-end noises - they too often sound like they're coming from the dash.
    Good to hear that the problem is rectified. Was it covered by warranty? 36.8k miles is awfully early for bearings to go.
    ice
    mlpontiusmlpontius Member Posts: 2
    jjocjjoc - in post 859 you described the same problem I'm having.. Transmission makes loud clunk and shudders when you accelerate quickly. In 865 you said it was a pressure control selenoid.
    Anyone know:
    Do you have to pull the transmission to repair or can you get at this through the pan. Can a weekend mechanic make this repair?
    98 Bonneville SLE
    The dealer worked with me. My son and I buy all our cars there. They also agreed that this was a premature failure.
    Ed
    That's the payoff for having a relationship with a dealer. Congrats - sounds like an otherwise bad experience was made that much more tolerable.
    ice
    dchandler2dchandler2 Member Posts: 2
    Is it diffcult to change the fuel filter in a 1998 Bonneville. Does the fuel system have to be de-pressurized? If so how do you do this? Also what other precautions should I take.
    rjs200240rjs200240 Member Posts: 1,277
    The filter is likely under the car near the side. Just follow the fuel rail. I've always depressurized them on the fly. Just unscrew part of the filter and it will depressurize itself... You just need to be aware of it ahead of time. It'll spray a bit and then maybe a few ounces will run out. No biggie, just be prepared (definitely wear goggles and have a container to catch the fuel, and let the spray have time to evaporate fully before you drive off with the new filter). The filter should be real easy to replace. Unscrew from both ends and screw in a new one. You'll probably need two open-ended wrenches of the same size.
    wazooworkswazooworks Member Posts: 17
    Hey, everybody!
    This is a minor one: One of the rubber-ish stops on the hinge mechanism of my trunk which cushion the sproing when the trunk pops open (darn, I wish I knew the exact name for it!) has broken, and the other looks to fail soon. I'm trying to decide if it's worth my time to go for a warranty fix, or replace them myself. But of course, gmpartsdirect can't find the part. Anybody have a clue where I could come up with a part number for this little insignificant doo-dad?
    Otherwise, my '02 SSEi is flawless and performs as beautifully as the day I got it.
    mlm4mlm4 Member Posts: 401
    That's a good question. There is no repair information in the service manual for these parts. I would call them "rear compartment cover upstops" but I don't know the actual name either. On my car, they are fastened to the hinges with nylon fasteners that could only be removed by breaking them off. The upstops are also painted the body color so they must have been installed along with the hinges before the body went through the paint shop. Maybe they come with replacement hinges but are not separately serviceable. Try going to a GM dealer's parts department and working with the parts guy. Ask him to go to "body rear end - rear compartment cover" (a.k.a. the trunk!) and see if there are any drawings on the computer that call those parts out. If not maybe it's time to improvise a repair. I would try to get a block of firm but compressible rubber and gluing it to the body cross member above the hinge rather than trying to attach it to the hinge as the upstops are. It's a nice flat surface. Good luck.
    (good name for 'em). I would check out parts recyclers - it would seem to me that they'd have more Bonnies with front than rear end damage.
    Wierd one though...
    ice
    Ice,
    Are you implying that it's more likely a Bonnie will hit something than be hit by something? :-) Well, I have seen a few wrecked 2000+ Bonnies for sale on eBay, and most of them did have front-end damage.
    I guess my answer to that, Michael, would depend on whether it's an SSEi or an SE ;-b...
    I recall a few years back when I was looking for front end parts for an old Volvo that wreckers were telling me that some 2/3 of write-offs were front end collisions. Either it's cars hitting larger immovable objects or other cars head-on or just that rear-end damage can be less expensive to repair (and therefore less likely to find their way to the auto yard) but front-end parts are way more difficult to find at a wreckers than rear-end ones - in my experience.
    ice
    mdjones333mdjones333 Member Posts: 1
    Hello fellow Pontiac Owners!
    After some intense investigation, testing and diagnosis, I believe I might be able to offer a "bolt-on" solution to the high speed wheel vibration issue we all have been facing. It seems that GM apparently got hold of some bad front hubs just out of tolerance. For those who are interested, two things are contributing to the issue: 1. The bolt circle is NOT concentric to the axis of rotation of the hub...some have been found to be very out of tolerance. 2. The hub and flange assembly is not evenly balanced. Same thing as the washer being out of balance during the spin cycle. The reason the vibration is somewhat intermittent and "comes and goes" is because both hubs are whacked, they sometimes will be "in synch" and cancel each other's wobble out, and other times will be out of phase and make it seem more pronounced. What has amazed me is that GM has now concocted no less than three (3) convoluted explanations and "fixes" ranging from varying rubber "stiffness" to "screened tires" and moon-shot type checklists to diagnose and attempt to fix the issue. One of their TSB's says "there is no easy fix". Oh..yes...except pull the damned hubs and replace them with ones that have proper geometry! At about $100 US per hub, that would seem like an easy repair, but apparently not easy enough to Mr. Goodwrench. OK...enough griping. I have borrowed some ideas from my USAF days and am working on a solution that should be as simple as a bolt on counterbalancing ring (kinda like the harmonic balancer at the crank) that will automatically keep the wobbles and shakes (especially when braking) away. Still in final development and testing stages, so stay tuned. If anyone has anything to add or can supply more data, please post a response.
    Mark Jones,
    Alameda Systems & Design
    Harrisburg, Pennsylvania
    p100p100 Member Posts: 1,116
    I do not own a Pontiac at this time (previously owned two 83 Pontiac Bonevilles though, both a V6 and a V8 model). I had a very similar problem that you are describing with my 99 Mazda 626 V6. I had an odd vibration in the car that would come and go and could not be corrected by rebalancing the tires. The front axles and CV joints were replaced under warranty and this alleviated the problem somewhat, at least the vibration would not occur under load at high RPM. When the mechanic finished replacing the axles, he had hard time getting the left front wheel back onto its hub. When I arrived home, I took the wheel off with some difficulty and then noticed that it would not go back on without forcing it on, and that there was a small gouge in the wheel center hole where it was forced onto the hub. I tried another wheel on this hub and it too would not go on without being forced on by tightening the lug nuts. To make the story short, I raised an alarm about this, the hub was replaced under warranty and the brake rotor was stuck on the old hub so they could not even remove it, so they had to replace the rotor too. Of course, the first dealer rejected my claim that the hub is defective, so I had to go to another one.
    I thought that my situation was unique because I never seen this before. Mazda installed some very low qulity parts on my vehicle, including hubs and axles. If I keep this car, I will have to replace all axles at my expense becuase the original and even the replacement ones are junk.
    Mark,
    Thanks for the info. I've suspected the hubs for some time but can't rule them in or out on this. I tried to get the dealer to look at the hubs twice but they blew me off as another ignorant customer. Usually a hub problem will cause the car to shudder badly under heavy braking, which is not the case here, so they say "it ain't the hubs." I figured it would be easy to check the stud runout but they wouldn't do it and I don't have the tools to do it myself.
    Please let us know what you find. What year/model are you driving, and have you replaced the tires, etc.?
    evandroevandro Member Posts: 1,108
    I'm not sure it's the hubs. It seems to resonate only at 70MPH, give or take 2MPH. If it were the hubs, it would shake at pretty much any speed. Besides, it seems to shake only when coasting or when keeping the speed, for the vibration goes away uphill.
    It's indeed a very weird issue. Maybe it's a chassis thing, maybe a half-shaft thing, or engine mounts... I don't know, but I don't think that off-center hubs fit the bill.
    bonnybluesbonnyblues Member Posts: 4
    I’ve been fighting highway speed vibration on a new 2002 SSEi with 17 inch chrome aluminum wheels since last summer. The vibration is noticeable above 100 kph (60 mph) and cycles from more to less over about a ½ km (1/4 mile). In some cycles the vibration is more severe and in others it is less severe. At times it almost goes away completely. There does not appear to be any variable that initiates the vibration or makes it any worse or better. The dealer replaced all the original RS-A’s, which were outside the road force allowance. The second set was also outside allowance and was replaced with ‘upgraded’ Michelin MXV4’s. Next, the lower A-arms with ‘better’ bushings were replaced. None of the above helped. The car was in the shop last week at GM’s direction to recheck everything. An on-car balance was attempted and failed to remove the vibration. The dealer suspected the left front hub was out of concentric and swapped in a new Grand Prix hub. He claimed this hub, with the Grand Prix 16 inch wheels eliminated the vibration (I never had the opportunity to confirm the ‘improvement’). However, the vibration returned when the 17 inch wheels were reinstalled on the Gran Prix hub (suspicion is that the low profile 17 inch tires are less pliable than the 16’s and exaggerate any vibration). The left front hub was replaced with a new OEM hub anyway. A recheck of the 17 inch combination showed maximum road force was only 4lbs (17 is considered acceptable). We await further advice from GM. It appears that the only thing that makes the vibration go away (according to the dealer) is to lose the 17inch tire/aluminum wheel combination. I ran across an SLE owner with 17 inch steel wheels with RS-A’s shortly after leaving the shop who reported no high speed vibration. Go figure!
    But I'm still puzzled by the fact that it only happens when the engine isn't pulling. Or does it happen only in my SLE with 17" alloy wheels?
    On my 2000 SSEi the vibration is most noticable at highway speeds but the range is greater -- more like 55 to 75 mph. Also, sometimes I can feel a wobbling at low speeds between 10 and 25 mph. That makes me think tires, but I still have the factory originals because I'm not convinced spending the money to replace them will fix this problem. I can't rule out that the hubs are also part of the problem, because it's likely being caused by an interaction of several components. The tires might be amplifying the problem, if anything.
    The curious thing is that late last year I rented a low-mileage Bonneville SE with the standard 16" tires and it had the same vibration as my SSEi, so I believe it is not just a tire/wheel problem.
    shaky1shaky1 Member Posts: 1
    I have a 2000 SE with 16 inch wheels. Had the Firestones replaced with Michelins. Had the forced balanced done. 1 new rim. Tires rebalanced and it shakes just like the day it was bought! Has 14000 miles and 4 months warranty left.I will be there everyday till the end!
    Inner CV joints on your axles, when defective, will cause unpleasant vibration that is primarily felt in the floorboards of the car and possibly shaking of the hood. This is what was happening to my Mazda before the axles were replaced. My Mazda is a V6 with a 5 speed manual. When accelerating hard and shifting at high RPM like 6K (the redline is 7K RPM), there would be serious vibration in the floorboards and the steering wheel and would go away when I let up on the gas. The car would also vibrate in the front floor boards at cruising speed of about 85-90 MPH. When this first happened, the car only had about 300 miles on it. I took it back to the dealer, and they checked the balance on the tires. All zeroed out on their balancer so they were balanced correctly at the factory. They told me some nonsense about this vibration being a common thing on front wheel drive cars and that was that. Well I did not give up, went to another dealer and this one confirmed that they have seen several of these cars with defective front axles and CV joints causing very unpleasant vibration. I had all axles and CV joints replaced, which eliminated most of the problem. Then I had the defective front left hub replaced. With the defective hub on I noticed some wobble and shudder upon braking at high speeds, but this was not consistent. New hub totally eliminated that. I believe that some manufacturers nowadays are using cheap axles and CV joints. I talked to several mechanics who confirmed that even on some Toyotas this is a problem.
    Vibration can be also caused by axles shafts that are slightly bent or out of balance. An axle support bearing with damaged rubber bushing (if it has one) could also cause vibration. Such bearings are used on RWD car and truck driveshafts and have been known to cause vibration when the rubber bushing deteriorates or gets torn.
    Tire balance:
    This is a problem, and a big one in this country. It is virtually impossible to find a place that will balance your tires correctly: I am on the verge of buying my own balancer because I cannot put up with having my tires balanced wrong over and over again. I have seen two different people use the same machine on the same wheels and come up with completely different results.
    First of all, standard US wheel weights are made in 1/4 ounce increments, or 7 gram increments. If one balances tires correctly using a balancer that rounds off to the nearest 1/4 ounce, it will be only marginal on an average passenger car. I had this done on my 98 Nissan Maxima using a Hunter $ 12,000 state of the art balancer. The balance was OK, but not perfect and I could feel very slight shudder around 85 MPH. Metric weights come in 5 gram increments, or about 1/6 ounce. This resolution is much better, so my advice is if you want better wheel balance go to a place that uses 5 gram increment metric balance weights and has their machine calibrated to the nearest 5 gram roundoff mode. I found this to be far better than balancing with 1/4 ounce weights.
    I checked out the specifications on many electronic balancers and their capabilities. Some machines made by Beissbarth, for example, have capbility to go to 0.1 ounce and 0.05 ounce resolution! This is 2.8 grams and 1.4 grams!!!! The problem is nobody makes standard weights in those increments. When balancing tires for auto racing they recommend accuracy to at least the nearest 0.1 ounce (2.8 grams) and using flange adapters in the wheel lug holes instead of the centering cone on the balancer. How many places that you have seen use flange adapters to mount the wheels on the balancing machine? And who will bother to make custom weights to fine balance your tires? Most modern balancers are capable of far better resolution than +/- 7 grams or +/-5 grams.
    Finally, tires. I never would have believed it if I did not experience this myself. Some tires sold are absolute junk. They take huge weights to balance properly (like 2 oz on each side) and on some belts will break in a short time. Broken or damaged tire belt will cause all kinds of unpleasant vibration, and the longer you drive the worse it gets. I had this happen with Continental Conti Touring tires (these were US made). These tires were junk. I bought two new ones to replace the half worn one with the broken belt, and both new ones turned out to be completely out of round and caused terrible vibration around 70 MPH. I jacked up the front of the car so that the tires were almost touching the floor and these tires were egg shaped when spun. The tire seller refunded my money on these but not the postage - it cost me $ 40 to pay postage for two tires two ways. I replaced all four Continentals with Michelin Pilot tires and peformed the same test. These tires were as round as they could be.
    Mounting four Micheline Pilot tires, balanced to 5 gram roundoff using flange adpaters on a good quality balancer, made all the difference in the world on my Mazda 626. Most vibration disapperared. However, about 25 K miles later and rebalancing of tires, I get some slight vibration at 80+ MPH that comes and goes. Probably lousy inner CV joints acting up again.
    A defective or damaged front strut could possibly cause vibration as well, because it is the strut that determines and maintaines front wheel alignment, and a worn strut will cause wheel hop, which will translate as vibration as well.
    I hope this will help somebody to solve their vibration problem.
    imidazol97imidazol97 Member Posts: 27,154
    I had an 80 Cutlass with tire and balance problems. Original tires were replaced with something called T/A. Don't remember the company. Factory rep wanted ram-tested tires put on. Didn't happen. 50K I noted the balance seemed only with tires more out of round when on front.(I used a dial indicated to check tread runout supporting A-arm with scissors jack.)
    Bolt patterns were off center; combined with minimal runout in tire/rim caused problem sometimes that came and went, just like talked about here.
    Balancing comment: New tires on 16 inch rims on LeSabre. Dealer has new force balancer. Cleaned up the Michelins right now. I had some balance problem at certain higher speeds. Service manager suggested coming in right away for force balance because of problems with Parks and Cadillacs like you're talking on Bonneville. He said they were replacing tires on those with Michelins because of least trouble compared to other original equipment tires. When I told him mine already came with Michelin Symmetrys he was surprised I had any highway vibration (at 1300 miles). My experience with lots of Michelins (10 sets maybe???) is that new tires always need rebalancing after 500 miles or so; then they act like they will the rest of their life, well-balanced or a problem tire.
    Never buy tire store tire when that model/size is used on new cars. I think that best ones go to the manufacturer and the culls go to the stores... Replaced originals on 89 century with same brand and tire that were nonMichelins because of great tread and grip and life. They shook; dealer didn't question me or try to rebalance, he just sold me the Michelins I wanted for the difference. He knew there were problems with those tires I had bought. The Continental story doesn't surprise me -- isn't Continental owned by Michelin now??? like Goodrich, and several otheres. I saw a chart at Tire Discounter store that listed who made all the brands they sold.
    My suggestion would be for the dealer to put on tires from a car (new?) that does not shake. Maybe fronts first, then add rears, to see if the tire/rim is the problem. Then try your wheels on the other car, to see if the shake moves with the tires/rims that you currently have.
    My service manual for 2003 LeSabre has a long check list for vibrations, including the bolt pattern being offcenter. That wasn't in my last 98 LeSabre manual. It's an indicator of where GM is finding problems.
    I'm in total agreement about the balancing. The same dealer (different techs) balanced all four wheels twice, the first time rebalanced all four, and the second time he found one wheel out of balance. A couple of the wheels have huge weights on them too. But even after all that there was no noticable difference in the vibration problem. Because it phases in and out and occurs regardless of engine load or braking (it's purely speed dependent), I still think it might be the stud runout out of spec. Also, since my car is driven less than 4,000 miles per year, maybe the tires are flat spotting too. I can't say for sure that the vibration has gotten worse since the car was new, but it seems like it has, although in the past year since I have really been paying attention to it it seems about the same.
    stanm1stanm1 Member Posts: 2
    Help! My 2000 SE looks like a cat in heat!
    The load leveler has gone whacky and pumped the rear shocks up to maximum. Looks pretty silly I must say. My guess would be that the load level sensor must be out to lunch, as the compressor motor sounds as though it is functioning normally. My question is, does anybody know where this sensor may be located? Just wondering if I can troubleshoot it myself as I really don't want to fork out the $$$ right now to have a garage fix it.
    Any ideas or tips?
    Stan
    alcanalcan Member Posts: 2,550
    Automatic Level Control Compressor
    Under the right rear of the vehicle, near the rear suspension carrier
    Automatic Level Control Accessory Inflator Switch
    Inside the rear luggage compartment
    Automatic Level Control Exhaust Solenoid
    Under the rear of vehicle,near the ALC compressor assembly
    Automatic Level Control Height Sensor
    Under the left rear of the vehicle, near the rear suspension carrier
    Rear Fuse Block
    Left rear of the passenger compartment, under the rear seat cushion
    Rear Integration Module (RIM)
    Behind the rear seat cushion (upper,left)
    "The suspension position sensor is a potentiometer which detects height changes at the rear of the vehicle and, in turn, relays these changes to the RIM, which controls the functions of the compressor and exhaust solenoid. To prevent energizing the compressor relay or exhaust solenoid during normal ride motions, the RIM provides a calibrated delay before ground is completed to either circuit.
    The sensor is mounted to the left rear side of the rear suspension support assembly. The actuation arm is attached to the left rear control arm by a short link."
    Make sure the link from the sensor to the control arm isn't disconnected. If ok, a scan tool is required to diagnose the system.
    bigred00bigred00 Member Posts: 13
    The Stablity Control System on my 00 SSEi just started acting up too. Twice, out of the blue, it has recommended that it be serviced. The warning does goes away with a re-start. A quick trip to the dealer determimined that it is related to the steering sensor for the magnasteer. Has to go back for further analysis. Car has 46,000 miles on it.
    zzoom1zzoom1 Member Posts: 31
    I have a 2001 SE model which needed a new intake manifold at about 23,000 miles which was covered under warranty. Dealer service rep said that there has been no redesign of this part, same plastic junk as before. When I bought the Bonny, I had always heard that the 3.8 series II v-6 was a great engine. Now I'm starting to wonder. It seems like it's not a matter of if, but when the intake manifold goes. Has anyone out there NOT experienced this problem? The reason that I ask is I've found a 98 Bonny SLE with 33,000 mile on it which I'd consider for my work car, it's condition is excellent, and the price is very fair, but if the engine blows????
    One way to look at it is to point out to the seller the nearly guaranteed intake problem and then devalue your offer accordingly, much like the late 80s to mid 90s Chrysler vans with their transmission problems. If he doesn't take, oh well.
    montanafanmontanafan Member Posts: 945
    GM redesigned the lower intake manifold for the 1999 model year and hasn't had a problem with the upper or lower manifold since. There are gasket leak issues with the 2000 thru 2003 Bonnevilles.
    bonnevillemanbonnevilleman Member Posts: 22
    Sorry it has been so long since I have written guys (my last post was in the 700's somewhere). I finally put my 95 SSEi in the shop 2.5 months ago after it developed an oil leak as well as the numerous problems it had before. I took it into the mechanic and when he asked me what I wanted him to fix on it I just simply said "whatever's wrong with it." Well that has been 2.5 months ago and the mechanic and I have gotten to be pretty good pals since then. After replacing almost everything electronic on the car (even the main computer) he is starting to rebuild the engine. Just wanted to give everyone an update on how this poor little bonne is doing. I have a feeling after I get her out of the shop it will be time to trade her in. I have my eye on a Buick Regal right now.
    Preston
    Today the sunroof on my 2000 SSEi ate the black plastic pop-up air deflector while it was closing. It had been starting to bind on the left side recently and I could see where it was rubbing and binding. I had meant to lube it (although the area that was rubbing never had any lube on it) but never got around to it. There's a rib that is flat on top above the track where the sunroof slides over the deflector and pushes it down, and the left one (the one that was binding) went CRUNNNCH! and broke off. After this happened I decided that it would be necessary to hold the deflector down with my fingers while closing the roof. Then it caught the right side and went CRUNNCH! and broke that one too.
    Interestingly, it now seems to work better than it did before I busted it. I'm thinking of just lubing the jagged edges and hoping for the best, but I've got a part number request into GMPartsDirect to see if the deflector can be replaced separately. Does anyone know if this is possible? It looks like it snaps into a hinge on each side. If not, then it looks like the entire track assembly will have to be replaced, because the hinges are rivet mounted to the track.
    Removal Procedure:
    Cycle the sunroof glass panel to the rear.
    Push down on the right front side of the wind deflector.
    While holding the right side down, complete the following steps:
    Push the left front side of the wind deflector towards the right side.
    Pull up on the left side until the lower tab clears the roof opening.
    Swing the wind deflector in an upward arc, rearward, in order to disengage the wind deflector from the hooks on both sides of the sunroof module.
    Remove the wind deflector from the vehicle.
    Installation Procedure:
    Engage the rear of the wind deflector into the side hooks on the sunroof module.
    Arc the wind deflector in a forward motion.
    Push the right side of the wind deflector down into the roof opening.
    Push the left front side of the wind deflector inwards and down so the tab clears the roof opening.
    Close the sunroof glass panel.
    Thanks. When I got home I looked up the procedure in my service manual. Looks easy. Got the part number, list price is $68.19.
    The deflector broke into two clean pieces (one on each side), so I superglued them back on. I doubt it will hold, but it's worth a try (at least until I order the replacement part). The plastic has a textured surface, so it's no wonder that the panel doesn't glide smoothly over it. Here's the left side, with the broken piece glued back on:
    lash92sseilash92ssei Member Posts: 35
    I have a friend that lives overseas. Does anyone know of a parts store that ships overseas?
    clipper52clipper52 Member Posts: 1
    I had a 2002 Bonneville that I had vibration at highway speeds the day I left the dealership. I was back fiur times with no luck to which I went to the lemon law. Gave them one last time to fix it. They re-balanced the hubs but it did not completely fix the problem. At that point I went to arbitration and guess what, the system works, BBB forced GM to buy the auto back and I am now the proud owner of a 04 GTP...
    They offered to put new tires on due to the recent release of TSP..check it out..
    Man am I glad to be out of that car..
    Sorry to hear about your '02. Many of us have had those vibration problems - I am not so cursed, fortunately.
    Congrats on your new GTP - I'm sure it will serve you well!
    ice
    mem300mmem300m Member Posts: 12
    I have a 94 B'vile w/114,000 miles. Last night the a/c fan went out. Regardless of mode (a/c, vent, defrost, heat), the fan will not blow at any speed or any switch position. Is this likely the fan motor itself dying or is there a circuit breaker or fan relay that might be at fault and if so how could I easily diagnose to see if it's fan motor or something else?
    please email me with ideas at mikemore@rocketmail.com
    Mike
    tdistancetdistance Member Posts: 1
    I just purchase a 1995 bonneville sse at the auction with 130k got a really good price for the car. Seems to be in pretty good condition however reviewing board I see a great deal can go wrong I have been driving for 2 days I noticed that the thermostat gage stays a notch above the overheat point when driving during the day and at about 200 at night. Is this normal?
    The a/c is not working. any suggestions.
    berrycherryberrycherry Member Posts: 23
    I had a similar problem on my Bonny SSEi 1988. It was the Blower Control Module that Gm wanted at $500 plus installation.
    Went to a junk dealer and got it for $35 and put it in myself. Mine was in the engine dept by the blower. It is an electronic module in the SSEi in 1988 , probally the same in yours.
    Good luck
    When it runs hot, stop and check to see if the fan is running.
    Also, you might be long overdue for a coolant change and system flush along with hoses. If you do the hoses, I think the 95 still had the little bypass hose around the water pump. GM had the "wisdom" for awhile of using a plastic threaded nipple for this hose that had the nasty tendancy to break. If yours is plastic, the replacement is metal and would be worth a few bucks for peace of mind.
    I can second the little bypass hose with the plastic tube threaded horizontally into the intake manifold. Mine had started leaking. I'd smell antifreeze at times, but only when having run hot so the pressure had been built up enough to leak. Other times, not smell.
    When I finally found water sitting on the engine top area underneath, the dealer couldn't get to it for a couple of days. I pulled slightly on the hose checking it when I got home and the thing burst. It could have burst at any time on the road.
    So I'd replace it and save the tow bill.
    Running at edge of hot: does the water pump look like it's been replaced since new?
    How does the antifreeze look? A flush on your own and replacement of antifreeze would let you look at the ends of the radiator tubes for corrosion buildup.
    Did your car have an air dam underneath to lift some air up in front of the condensor and radiator? Is it still there? The one on my 93 (LeSabre) was easily rubbed on parking blocks and yours might have been broken away.
    jeromy1jeromy1 Member Posts: 5
    My mechanic has traced my '95 Bonneville's (6 cyl. SE 3.8L) starting problem back to the starter (of all things). He says everything else--all the wires, chargers, alternator, you name it--looks good. The car has gotten the bad habit of shrieking instead of starting 4 times out of 5 when the engine isn’t warmed up. It’s gotten progressively worse, to the point where I can’t depend on it starting at all, so I took it in.
    I’m not much of a mechanic. I could try to fix it myself, but not this time. The mechanic quoted $249 for parts and labor for replacing the starter. It’s a new starter with a lifetime warranty that costs $120.
    Is this a reasonable quote?
    Starter replacement labour is 1.1 hours.
    Just had mine redone at 4000 miles by dealer. The force balance had changed from the earlier run at 1400 miles. He also reduced the tolerance on the balancer to zero. He explained that the usual tolerance of 1/4 ounce can leave 1/4 oz on both sides of the tire, causing more than that in imbalance.
    The tires have been problems through the years. The force balance measures the out of roundness due to uneven sidewall crushing while rolling. Less than 17 is acceptable. They replace some with Michelins to get that tolerance. Mine were 9 or lower to begin with. They had not found a wheel hub to be off center on any problem cars. It's all in the wheels and the light weight of the aluminum suspensions on Bonnie, LeSabre, Deville, Seville, ...
    It makes them much more sensitive to wheel runout and balance. So if your dealer just balances to nearest 1/4 oz and doesn't care, lots of luck... My service manager was checking it all out this second time around when the balance vibration came back. He used a vibration analyzer on the seat frame after the rebalancing and couldn't get a reading that anything was in harmonic motion in the car.
    I couldn't feel anything either on the way home...
    PS One additional factor mentioned by radio mechanic was tires slipping on rims. He suggested marking rim and tire with a dot of fingernail polish. I can see hard braking letting
    the tire slip if installed with too much lubricant. The lube stays around for a while and can
    let the tire slip. A tire slipped changes the runout if it was matched to the rim for minimum
    runout. I don't hotrod this car, but emergency braking could cause a tire to slip.
    rcastonrcaston Member Posts: 1
    turns out there is a defect on the intake manifold's on most of the GM car lines, like the Bonni..
    basically, they crack around 60,000 miles, pouring engine coolant into your engine, as in, where the OIL is.
    So I hyrolocked my engine, it won't start, and I had to replace the manifold, and drain coolant out of my engine before it ruined it.
    total bill, $1200... tho some people's bill reach into the 4k range if they blow other gaskets, like the head.
    I signed a online petition with 5,000 other people with this same problem.
    My advice to anyone who has this car, get it check'd out around 50k ...
