I need some suggestions to assist me in pin pointing the problem.
See you there.
ice
Just bought a new 02 SE a few months ago and it has about 3k on it.. I cannot seem to get the interior to defog in cold weather.. The front windshield is fine but the pass and driver windows will only defog a little and the back 2 windows not at all.. I think im working the climate control right (defrost/high fan/outside air). Any suggestion appreciated
Again, thanks
I did notice that the rear window defogger draws a considerable amount of current , as the voltage drops by about 1V when idling, but it remains at around 14V when cruising when it's on.
If your city driving includes short trips with the engine warming up much of the time, you're lucky to get 15. My wife drives our Caravan 1 1/2 miles to school and I have seen our mileage as low as 11 for a car rated at 19.
I had problem in 98 LeSabre 3800 at 70000 mi. GM told me warranty expired. Service manager said he'd seen a lot of these. Customer noService at GM plain rude and short. This to a 7 Buicks in-a-row owner, last two LeSabres. Had planned to buy Park Avenue next.
I did buy a 2003 3800 LeSabre -- discounts + wife wanting different car overcame reluctance due to GM's not supporting their flaws. I won't have GM card discount to cash in after this. I'll buy used from now on. If I'm going to have to pay for repair of flaws, at least I won't be paying new car price. 3 yr. 36000 is a joke as a warranty period.
Problem and handling so far by GM really has hurt their image in my eyes. I'm one of their younger LeSabre buyers--I plan to buy several more cars before I am too old to drive.
GM needs to wake up. A $250 credit toward a new car or parts or service at that time would have satisfied me. Now if they do ever cover it post facto, I want the full cost of the plenum and labor (I'll pay for the water pump at 74,000.)
Friend's Bonneville (98) had leak into engine. Stopped engine. Had lifter problem with noise right after that. I never did hear how much that cost them.
The dealer initially rebalanced the tires... no difference. I asked for a road test with me in the car and the dealer agreed that I had a 'valid complaint'. After checking the front end and repositioning a suspected tire on the rim, the dealer concluded that all tires needed to be replaced. Same brand/model new screened tires were installed... same old vibration!
Before I get into round three with the dealer, has anyone been able to cure this apparently not uncommon problem? I already know about TSB 00-03-10-007A; however, the dealer may be reluctant to conduct such an exhaustive analysis. I'd like to cut to the chase!... if there is one.
Any advice would be much appreciated.
go through? Could you or someone post a copy?
I've always found Michelins fixed vibration on
H-bodies I've had that could be spin-balanced
out. I put XH michelins on one. Another I put
X-Ones on more recently. It had Generals OE
that didn't roll round after 40K.
The worksheet indicated 1/2 hour was spent looking at the front end.
Hope this helps.
Does DexCool types cause more problems than original type antifreezes? Is it possible to flush and get all DexCool out and use earlier type antifreeze? Would it cause more or less trouble with seals and intake manifold water passages?
This all makes me just want to run down to the dealer and buy another GM product!! This bonneville was my first and is now my last GM product.
I too have had no luck with this same vibration problem on my 2000 SSEi. They replaced a "worn" tie-rod end, but no improvement. They balanced all four wheels (also did a road-force balance), and match-mounted a couple of them as well, but still no improvement. I would suspect the tires themselves, but from what I hear, new tires may not fix the problem either. The dealer has not offered to replace them...yet. They were pretty responsive at first trying to help me out, but now I think they are ignoring me and hoping I might go away quietly. Both the tech and service manager (who both test drove the car separately) kind of suggested that this is a design flaw that they cannot fix (without actually saying so much). One owner some time ago posted here that it was a problem with the hubs, that the stud runout was out of spec. I have twice asked the dealer to check this and they have so far refused to do what I think is a pretty easy check.
It's frustrating for an otherwise good car, but it seems that most cars these days have some sort of design flaws that plague their owners (not that that makes it right!).
it myself using a gauge and rotating the studs.
Sometimes vibration was there, sometimes not, on different days. Moving tires around made it lesser and greater. Very strange.
Per the owner's manual, check it when cold and add to the bottom of the fill hole.
Mine started getting a little louder (checking it when the book said), so I took it to the dealer for a check-up. They said the oil was scorched. They replaced the supercharger at 65k. The part is $2500, but with the extended warranty it cost me $50.00.
I now have 76k on the car and that has been the only problem I have encountered. No rattles, shakes or anything.
What a great car.
2000 SSEi. Delivered 01-25-00
You cannot get it from underneath. I follow the owners manual directions; remove the two bolts on the inner side of the headlamp assemby and the assembly slides out. Wrong. It moved but there seems to be more inside and unreachable that needs to be removed. AM I missing something. Plese help if you have done this. Feel free to e-mail. Staron1@att.net
1. If you have the filter enclosure (most cars don't) then you need the whole "enchilada" and the # is 25669930. I got it @ GMPartsDirect for $38 including(!) shipping.
2. If you have the enclosure (you see a black plastic frame inside, when you open the cover) then you need the filter only, # 25654414, ~$14 @ GMPartsDirect.
I personally drive daily through an area with rather "unpleasent" smell. Since I installed that filter MY LIFE HAS CHANGED!
Don't buy it at the dealership, they charge ~$34 for the filter only.....
Does anybody know if the part # changed for the good part, if it exists? The part # of the replacement was 17113136.
I've also noticed that the gasket (part # 17113137) was not itemized in the replaced parts list. Shouldn't it have been? I asked the service guy and he told me that 17113136 is probably a kit that includes the gasket...
Does anybody have a TSB about this issue?
TIA
If you e-mail GMPartsDirect with a specific part you are looking for (give them as much information about the vehicle and part as you can), they will look it up for you and e-mail you the part number. Worked for me.
I agree that since the battery is under the rear seat (and inside the passenger compartment) it may last longer. Heat kills batteries, and under the hood it is very hot. Most batteries these days should last five years, although down here in Florida it is often much less than that.
I hope this solves this one for me . It only took about an hour or so to repair. Thanks , Bill
I did confirm with the service assistant that the upper manifold # 17113136 does include the gaskets between it and the lower manifold and between it and the throttle body.
What gives me the creeps is that, unless the original part was from a bad lot, just replacing the upper manifold doesn't address the issue... I was lucky that this time the coolant leaked outside the engine, for had it been inside we'd be talking about a potentially severe engine damage.
Heck, I saw -30°C (-22°F) on the Bonnie's thermometer for the first time ever just last week! Started first time like a charm. I wouldn't even think of replacing a battery that can handle that at 3 years. Perhaps before next winter though...
the (well-named) iceman
But the $550 you spent for the two manifolds and the gasket will keep you car going for a long time hopefully.
John B.
