Has anyone else had this problem? My dealer says he hasn't heard of this complaint. Any ideas on what it might be (please don't say transmission or engine problems)
--Chris
In my 626 I had a similar thing happening in the same rpm range. It was the heat shield that covers a pipe right between the exhaust manifold and the cat-converter. I went to Home-Depot, bought a couple of 1 and 1/2 inch worm clamps, and voile, noise gone. If you have access to welding equipment, I'd suggest you do it that way. A couple of welding points will take care of it.
G.
Can it be just bad gas? The station was running out of gas that day. Is that the kind of failure from bad gas? What else could it be?
As far as the spark plugs, I change them every 60,000 and use good plugs. I have also noticed that when I remove the old plugs the condition is fine but the gap is near the wider end of the tolerances. Then when I put in the new plugs, I set the gap to the narrow end of tolerances assuming that it will increase over time. This seems to cause some engine pinging. So do I need to just reset the computer when changing plugs or does an engine with 150,000 miles run better at the wider limit of spark plug gap tolerances?
Attempts to shift into reverse occasionally don't work -- the shifter makes it only part-way into the gate and cannot be moved further. If I let the clutch up it grinds.
If I shift back into neutral, let the clutch up and then put it [the clutch] back I can complete the shift but it seems a little bit rough.
The shifter seems to make a creaking/grinding noise (very slight -- only audible at low RPMs or when the engine's off) that show-floor models don't make.
If the car had done this from day one I wouldn't be concerned, but its just started doing it now. The dealer couldn't duplicate the problem and the service manager says its "normal because reverse isn't a synchronized gear". I'd be more inclined to believe him if this behaviour had been consistent since I got the car, rather than being a recent development.
Anyone have any ideas on this? Suggestions? Is this normal behaviour (its my first non-beater and my first standard) or should I be concerned?
Any advice/comments would be appreciated. Other than this, the car's been wonderful -- a really nice experience.
I think I read it somewhere over at www.protegeclub.com/forum
Can't help much more than that...sorry
As for the creaking/grinding noise - I'd have to hear it to know if it is normal - some creaking is, grinding though maybe not so.
Dinu
Just purchase a preowned '02 P5 in Vivid Yellow. Had more than usual chips in the paint on the front that I attributed to hazardous conditions frequented by previous owner. Unfortunately, with greater than my usual care, I am seeing more and more chips in the paint and I've only been driving it for 10 days! Has anyone seen or heard of problems with the paint on a P5 being overly fragile or lacking adhesion? This would be a tough warranty claim, but seems to lack ANY durability. Thoughts?
Anyway, I have a new (2000 miles) Protege LX. A few weeks ago, the right front door developed a slight rattle. It sounded vaguely like the door wasn't closed properly, but that clearly wasn't the problem. Then today I noticed that the right front window was making a sort of rubbing sound while being closed. Do you think the two noises are related? Is either or both a common problem?
I will soon be taking the car in for its first oil change/service, and I would like to have some ideas in mind when I tell them about the door and window, especially if they tell me to ignore them. If anyone has had a similar experience, I would greatly appreciate hearing about it.
I have had the same "creaking" that you experience with your shifter. Your gear shifter uses Teflon bushings and these have likely worn through due too, ahem, vigorous, frequent shifting. You also likely require a lubrication of the shift housing. If the car is still in warranty then the dealer should have no issue with a lubrication and installing new gear bushings. The bushings are something like $14.00 CDN if my aged memory serves me correctly.
Good Luck and I hope this helps.
Tim
See you,
Tim
It takes about 15 minutes to pop off the door trim panel, if you know how to do it.
Mucht thanks to Tim's for his suggestion about the shifter's bushings. I'll ask the dealer about these at the next service check.
Finally did it this weekend, and I looked at the instrument panel/dashboard dimmer switch, and the rear window defogger switch, both of which were pooched. The rear window defogger is definetly toast, as pieces flew out as I took it - It had no bulb inside, etc. It was easy to test that everything else worked because I used a piece of wire to 'turn on' the defogger, and that's fine. Now, the instrument panel/dasboard dimmer is a more convoluted piece, with a voltage regulator PCB on it. I checked and two of the transistors on it seem to be 'post pactory', as you can see poodles of solder flux near the legs. I think I can figure out what all the components do (I used to work in an electronics workshop), but it may be overkill to try to fix that piece.
All this ranting for a very simple question. How much money am I looking at, and where can I get these things (the dealer, I know, will charge me a yon of dough for 1 dollar of materials...)? Any good used part store over the web that actually sends you what they sell you?
G.
Called the dealer yesterday for prices on the dimmer and rear window defogger switches - They want 80 for the one, and 45 for the other! Ouch! In any case, I digged around and realized that the dimmer works by 'floating' the ground that the instrument panel/dashboard lights see. They are always connected to +12v when headlights are on, but the ground is made to 'float' by the little dimmer. Meaning, you can jumper the whole thing to ground (actually, two pins), and you get the dashboard ilumination back, at the level I always had it in all my cars (full power). I am now seriosly considering just leaving the jumpoer on and putting a little plastic cover over the hole.
As for the rear window defogger, a big on-off switch will do fine. G.
Beachnut ... Wow, that car has been abused. Stay away from it. I was the owner of a '92 LX I bought new, and when I sold it with 83,000 miles on it, it was still running and looking new. Don't accept any car that has been abused like that. And btw, the timing belt should've been replaced at 60,000 miles. Failure by the original owner to replace it nearly 30,000 miles after the fact (halfway toward replacing the SECOND one) should be a dead giveaway right there as to how the vehicle was treated.
Meade
Owner, 2000 ES (45,000 mi.) & 2002 P5 (10,000 mi.)
My '91 LX has 160k and will probably be donated to the Kidney Foundation before it gets it's third timing belt. The clearcoat is getting thin on front fender tops, but it still looks pretty good. The other thing to check is look at the seams on the door edges, especially the bottom and hinge sides. Mine is definitely showing rust and splitting at these sites. Engine is getting a death rattle on cold mornings, too, but it still pulls strong, once warmed up.
Gotta say, though, we definitely got our money's worth out of this car! Good luck on the hunt.
Dinu
Even better now that you own a Protege!
--Dale
Thanks for the advice on junk-yards. As the former owner of a GLC when I was a student, yeah, I vaguely remember junk-yards. I think everything I replaced in that car was obtained 'pre-owned' from junk-yards. But my problem is I don't have all day to go from one junk-yard after another looking for parts - That's why I wanted to know if someone already knew about used parts 'stores'. In any case, I did a 'nicer' jumpering of the switch, and now even the light on the dimmer shines - No cables dangling off the dashboard.
When I picked up the car a month ago it had bad rotors/pads/shoes. I replaced them a week after, and now that is fine. However, I have started noticing a 'clunk' coming from the front end every once one in a while. At first I thought it was a caliper sleeve not sliding properly, so I took the boots apart, the sleeve out, cleaned the caliper, and greased the sleeve. This, for a while, or at least in my head, seemed to work. Now, I realized that the noise comes when I brake while turning. It's not your typical CV-joit noise (rack-rack-rack), but more of a 'thlunk', and it does it once and that's it. I also feel it on the brake pedal. My fear is that I my powers of persuasion when taking the old rotor out (i.e., I banged the s**t out of it), screwed up the wheel bearing or some other suspension component. Or it could be the CV-joint, but no noise when turning and accelerating.
Car is a 96 DX. Any ideas welcome. G.
Not sure of how to do that in the '94, but it's pretty easy in the 99 models (first one took me 45 minutes, the second one about 5). Your mechanic probably knows how.
Well, my caliper problems continue. As I mentioned in #1281, I thought the 'clunk' could be associated with turning+braking at the same time. Apparently it was a coincidence. It clunks in straight lines as well, but it's very erratic, and it does it every once in a while. So, I'm now more convinced that the sleeve is still sticking. Is there something special about the sleeve and its housing in the caliper, or is it just a machined 'tube' sliding through a 'tunnel' in the caliper? In other words, are there bearings or other movable parts that help the sliding of the sleeve?
TIA for any advice/words of wisdom, G.
Frankly, when I bought the car new, I thought it would be temperamental, being a high revving engine. But it's proven to be very tough and durable.
I think you'll like it.
Thanks again,
G.
culprit:
power steering??
wheel bearing??
I have a '00 Pro ES with ~68K miles.
I've recently noticed that my Pro will shake/vibrate like it's not getting any gas. The engine light will start flashing and then remain on. If I drive it for a while, the vibrating stops and I can drive it fine, but the engine light stays on. I took it to a service station where they convinced me to have a "Induction Service"--deposit/fuel injector cleaning done on it. They also fished the computer code out and found that it was misfiring, but they couldn't reproduce the failure. They also wanted me to replace the spark plugs and wires which I did not have done since the plugs were just replaced. The work that they did did not fix the problem.
The next thing I plan to do is replace the wires myself, but if that doesn't fix it, does anyone have any ideas what else I can do to try to fix it? I remember this same thing happening when I used to have a 323 and I think the wires were bad. Anyway, if new wires does fix it, how can I get the engine light to shut off?
Another thing I'm noticing is that sometimes the brakes make a groaning/creaking noise (like an old floorboard) when coming to a stop. I just had the brakes replaced at Midas (discount brake shop) and they said the rotors would need replaced in a year. Could it be the rotors need replaced now? Or maybe it's brake dust? Any ideas on that problem would be appreciated as well.
thanks,
"Induction Service" that's what you get for stopping at a gas station instead of a trusted mechanic/dealer.
