Oil leak?
I need help. I added a quart of oil to our 1997
T&C (3.3 V-6, FWD, 78000 miles) last week on
Thursday, I believe. Well, I checked it again today
because I smelled oil burning. It was a
half-quart low. The van has only been driven 300
miles or so at max since I added the oil.
Realistically, it's probably more like 200 miles.
The car doesn't leave oil on the ground, and it
doesn't smoke. The engine block, however, is oily.
The van has always had an appetite for fuel- a
quart about every 1500 miles- but never like this.
Am I making a mountain out of a molehill, or do I
have a serious problem here?
DH
Thanks, John
Thanks, John
This is directly beneath the throttle body on 3.1L engines & beneath the rear head on 3.4L engines.
To repair the 3.1 remove the throttle body, It will be the round object with the U-shaped hold down. Remove this bolt & with a ssssmmmaaaallll pry bar and vise-grips and or channel lock pliers try to lift lightly under the lip while turning back & forth with the pliers. The complete unit is near a foot long. The o-ring near the top is the culprit, it dries & either shrinks or cracks with age. When replacing you can apply some silicone gasket compound under the lip to prevent failure longer - maybe.
The 3.4L requires head removal to do it correctly but a possible fix would be to loosen the clamp on the round projection under the inner slope of the rear head on the drivers side. If you can lift it and apply sealant such as orange hi-tmp silicone "evenly" under the lip it may hold. The sealant should be left to dry overnight without using the vehicle -- make sure you tighten it down first.
I was concerned about leaks in all areas, but the engine is the only leak, and it is only a drop or two per day, but I want to get it fixed. I'll take a look at it this weekend and see if it looks like something I want to tackle. From your note, it really doesn't seem to bad.
Thanks, John
Garaged, elderly woman drove it, children selling for her. Very nice. Driven only 2-3 times a week.
Loaded options.
I own all fords(no comments pls)so don't know this design/motor, etc.
Any comments? what to look for? good year for this car? etc. Please tell me all you know. Thanks.
