Mitsubishi Mirage Maintenance
Hi everybody,
I have a 93 Mirage 1.8L Engine 4 speed A/T with
70k on it. I just did couple major tune up:
Changed: Air cleaner, spark plugs, ignition wire,
distributor cap and rotor, brake rotor and brake
pad, A/T Fluid Changed, Engine Oil change and
flushed radiator and changed coolant.
Adjusted: Engine Valve clearance, ignition Timing
and idle speed.
Going to replace the timing belt and the 2 drive
belts next weekend.
Everything is right at the factory specification,
dead nut.
But the car(I think it is from the engine), still
runs noisy suddenly, and only, at around 30 mph
and
40 mph. I think that is the speed range that the 4
speed automatic transmission shift from 2nd to 3rd
gear(30 mph) and from 3rd to 4th gear(40 mph).
However, it will run normal again after that speed
range. I am driving 70mph all the time and this
Mirage is really smooth and quiet. This car is
giving me 28mpg on mostly local driving(with A/C
on
all the time) which is not bad. But I cannot think
of any reason why in that speed range(probably the
engine has just shifted from higher RPM to lower
RPM while the transmission has just shifted from
3rd gear to the the 4th gear) the engine will
become noise. My car does not have a Tach. on it
so
I cannot tell exactly what RPM the engine is
running at that point. I my guess will be at
around
1700 - 2000rpm.
I mean, if the ignition timing and valve clearance
is perfect and the engine does give good gas
mileages, why would the engine "roar" at 40mph
while the engine is running at lower RPM due the
the shifting up a gear?
Does anybody have this same problem with thier
1.8L Mirage?
Also, I noticed the Mirage's 1.8L engine has a
higher 9.5 compression ratio, does it "require" 93
octane fuel?
I understand this may be too much for an ordinary
driver but I really appreciate any input.
Ross
and idle speed.
belts next weekend.
dead nut.
and
on
so
around
1700 - 2000rpm.
1.8L Mirage?
octane fuel?
Ross
Thank you,
Jessica
ALSO, do some searches using the search feature on the sidebar.
This conference is about people with Maintenance and Repair issues, so your question is sorta off-topic for here. I don't want to discourage you from asking people's opinion though. That's why we're here, but I swear you will get a better response in Sedans and Coupes.
Your host, Bruce
ALSO, do any Mirage owners know of the brake indicator light on the dash coming on at random times for no apparent reason? We replaced the brakes on the car maybe 2-3 years ago and they work great (we had them checked out in the inspection too and once again they're OK), but that light keeps coming on and frankly it worries me. I've had my brakes give out on me when I was driving in another car, and it's not an experience I'd like to repeat!
Schaffs
I've found the brake light turning on on my 5sp Mirage coupe, same year. I found that while shifting or reaching for something in the console, I would pull the brake lever only enough to get the light to come on. Also, it may be a faulty sensor (does it have ABS?) Get the computer codes read at a reliable shop and it may tell you what's wrong. If the brakes where done 2-3 YEARS ago, depending how much milage the car gets, it may very well need a brake job. I find my slef doing pads about evey 20,000 and rotors every 50,000. (I do a lot of in town driving, and stop and go.)
I just check the servce manual and I found out the the gear ratio jump from 1.000 to .685 when shifting from 3rd to 4th gear which is quite a lot. I think at such a low rpm at 30-40mph, the 1.8L engine does not provide enought power.
Recently, I just found the when I am driving above 60-65mph and I press the brake, I can feel the brake pedal vibrate and the cars does to brake so well. However, if I am driving less than 60mph(lets say 55mph) the car brake really well, quiet and decelerate pretty quickly.
Note: The frond brake pad and rotor are brand new (only 1 months old) and the rear drum brake has been cleaned 3 months ago.
Does anybody have the same problem with their Mirage>
bearing2000
Please let me know.
Also it sounds like bearing2000 schaffs2 and I all have the same "humming" noise problem... I haven't heard it since we got the brakes done but I think that's just a coincidence. So anyone with a breakthrough please keep me posted!!
Everything I have found is focused primarily on the cover-up (including two USA Today articles) with no details of the recall that would be useful to Mirage owners.
Perhaps more information will be forthcoming over the next few days. Or maybe someone else can find more info than I did and give us a link.
Meanwhile, I'll keep looking, and I'll post here anything I can find that really explains what the recalls will be.
Pat
I have a 93 Mirage and I feel some vibration from the steering wheel when the speed get up to 75 mph. I do not feel any vibration at 70 but, gradually, the vibration magnitude increases. It is pretty obvious at 75mph.
Does anybody have this problem?
I just adjusted the alignment three months ago and the tires are pretty new.
I am thinking about, may be the drive shaft has been bent a little bit due to the explosure to the "bumpy" road condition for the last seven years.
Symptom: The engine started and then dead after 1~2 seconds.
Can this be related to engine oil? I didnot change oil for about 5 months (only 800 miles during that time) until I saw the check engine light is on. Then I poured half bottle of 10w40 oil into it. And then it refused to start.
Schaffs3
