Escalade Dead Battery Problems
Twice we have left our Escalade at the airport for
a one-week period returning to find the auto with
a dead battery. The dealer seems to be stumped as
to the cause, however, a Denali owner has also had
this exact same problem. Anyone else have this
problem? Know the reason?
I've done this in the past:
Disconnect the battery and put an ohmmeter across the battery leads (not the battery!). The resistance should be infinite or very high. If it's low, it indicates that there's a load somewhere. If there's a light under the hood, take the bulb out so it will open that circuit. Make sure the doors are closed so the dome light circuit is off. Make sure any other light or accessory circuits that are always active are off.
You can remove fuses to try to isolate which circuit the problem is in. Don't forget the fuses for your aftermarket alarm or stereo if applicable.
Once the regulator in my Taurus shorted out and drained the battery completely while parked at the airport a couple of days. It measured 2.7 ohms across the battery leads, roughly equivilent to having a 30 watt bulb left on all the time.
My wifes Mercedes recently had a similiar problem, where the battery would not maintain a full charge even though the battery and alternator checked fine. It turned out to be the climate control, which is powered all the time (the servo needs to return to the parking position when the ignition is turned off). Good luck, electrical problems can be a pain.
Michael Solomon
Escalade Brand Team
Michael.Solomon@GM.com
I am not sure the charging meter is accurate as it indicated only a mid level of charging when the battery was totally dead.
stannova1
