Oldsmobile Achieva Shudders and Shakes
My 1992 Olds Achieva begins shuddering over 45mph
and continues all the way up to about 70. Seems
worse when the torque converter clutch is locked
up. Doesn't really show up in the steering wheel,
just feels as if the whole car is moving or
"bucking" slightly. Anyone else experience this
and know what causes? Dealer drove it and said it
runs great.
runs great.
That's my first pass at your problem...
The car has about 95,000 miles on it, and runs great except for the shudder. The TCC seems to lock and unlock just fine. If I get it to unlock at 45mph or so, the shudder seems to go away. I do have some other shakes that might be wheel balance or CV joints?
Definetly does seem like something is amiss when the TCC is locked. Doesn't quite seem like an engine miss.
Car has been doing this since about 70,000 miles. It has not gotten worse since then, just stayed the same. 3 dealers were unable to determine what is wrong.
Appreciate any help you may offer.
One other thing... how does one know when it is time to replace the CV joints/front axle assemblies??
Scott
On my '84 Skyhawk FWD, I just replaced a hub/bearing and the CV axle. I had a thumping noise that turned out to be the hub/bearing; When I had the front end on jackstands, I first checked for bearing play side-to-side and in-and-out, but there was none. I then put the tranny in neutral, and spun the wheel... I heard a faint noise from the hub, and felt little roughness from the CV joint. I re-checked the joints by turning the wheel full left and then full right, rotating the wheel each time. I determined one outboard CV joint was bad, and replaced the entire axle assembly for $100 (Pep Boys). The hardest part was popping out the lower ball joint, which lowers the lower control arm, and gives you the clearance to pull the axle out of the transaxle.
I noticed immediately with the new axle that the car turned easier, which makes sense. From what I'm told, 100K for a CV joint/axle is pretty good.
Another possibility is tranny fluid level and condition... when was the fluild/filter last changed?
Wheel balance would be another easy check...
Good luck!
One is definetly under load (drivetrain). If I downshift the car, the TCC unlocks and the engine revs and that shudder goes away. I think this is similar to your recommendation to downshift.
I think I do have something screwy with a tire. Been getting rebalanced every six months, and one has a ton of weight on it. The place where I bought the tires said the rim was bent. Everyone else who has balanced it felt the rim is OK. I'm not sure what to do with it... about ready for new tires anyway so I thought I'd try that first.
Is there a good way to check for a bent rim besides throwing it on the spin balancer and looking for a wobble?
The tranny was flushed and filter changed at aroung 65K miles. Shudder existed before and after this.
One new development that might be related? Last night in heavy rain I drove the car through some small puddles (it's the wifes's car.. I don't drive it too often) and noticed that the car REALLY pulls to the side that the puddle is on. These weren't big puddles either.
Thanks for all the input so far.
A wheel may not start to hit a wobble frequency until 70 mph. Whatever caused the bent rim, pothole???, the tire damage may be internal, as in a shifted belt, which is very tough to diagnose, but certainly is the most probable cause of the shudder. In addition, the bearing balls and race in the hub/bearing assembly may have been flat-spotted from the impact that caused the bent rim.
My advice? New rim and new tires. Get a name brand tire too. The cheap tires are not molded with as tight a tolerance as speed-rated tire, as in a H-rated tire, for example, so more balance weights are needed and the chance for imbalance at higher speed goes up. If it's a steel rim, you can get one pretty cheap at TireRack http://www.tirerack.com. Probably $35.00 or so. If it's an alloy rim, look either at a junk yard, or http://www.aaarims.com typically has overstock sale rims for GM FWD vehicles. Once the rim and tire are replaced, drive it at 70. If the shudder is still there, I'd check the hub/bearing.
In regards to the puddle, the tires must be low on thread-depth... even a small anount of water can make a worn tire hydroplane, where it temporarily loses contact with the road, which is the pull you felt.
Glad to help.
I will be putting new tires on the car this week, so I'll let you know what happens. The tire place said they can check the rim while it is on the spin balancer. Do you think this is an OK way to check it? I figured you would need a dial indicator to see if the runout is in spec. They seemed to imply you can visually watch it.
The car has new rotors (the original ones warped within the first 40K miles).
It has one new front wheel bearing. I was thinking of replacing the other, the shocks, both axle assemblies and the rear bearings. Figured I should start with the tires and rim first.
Thanks again for you help
Also... I was leaning towards Firestone Supreme SI tires. Any feedback as to this choice? Price seems right, $70 mounted. I plan on driving the car only part of the year to give my truck a break until the snow season arrives.
Also, if it is warped rotors, make sure the rear brakes are functioning and adjusted properly, as poor rear brakes force the fronts to do all the work.
So I'd start with the new tires, get an unbent rim, and check the rotors.
Thanks again for your input.
After this is done, I'm going to check into the rotors.
I'll let you know whats found.
To start... tires had shifting belts... new Dunlops fixed all of the shudders not associated with engine load.
As for the miss under load, new EXPENSIVE spark plug wires totally fixed the problem. New CHEAP wires did not. Moral of the story... buy factory original wires... I wish I did.
Shakes/Shudders --> Most engine caused shakes will occur as soon as the overdrive torque converter kicks in at a speed of about 45 mph (80 km/h). This does not mean that they do not occur at other speeds in other gears, but due to the nature of an automatic transmission, the fluid absorbs most engine power irregularities. When the converter kicks in, the auto tranny is "bypassed" and the car becomes like a manual if you will. Therefore, you will feel any shudders from the engine. As for the cause, most people mistake it for the torque converter solonoid or something to that effect. In fact, it is usually the electronic ignition system. Check the ignition control module, electronic distributor, wires, plugs, and all associated sensors as well. A diagnostic check will help. And check for a miss under a load as well.
Stalling--> Most stalling (especially as soon as the car is put in gear is caused by faulty sensors (oxygen sensor, mass airflow, idle/air control sensor, etc.) or control units such as the ICM (ignition control module) or the ECM (engine control module). Also, mechanical failures such as the EGR valve siezing are common as well. Have these checked and also have the fuel rail pressure monitored after the engine is shutdown as well to check for faulty injectors.
Let me know how you do with your problems. Good luck!
