DISAPPEARING OIL!
in General
I own a 1991 Subaru Justy with 90k. Lately, I've
been noticing that the oil level is down almost
every week. I thought the car was burning oil, but
then I drove it only a little for a few days, and
it was 1/2 quart low again. I see no oil in the
driveway, and the engine is relatively clean. I
just don't understand where the oil is going.
Could it be possible that oil only leaks when I
drive the car, then when it sits, there is no leak?
Could the oil be forced out under pressure while
I drive? If so, where should I look for this?
These are simple things but may help to determine the cause. If you see a leak then the need for repairs is obvious.
If blue smoke comes out of the tailpipe when the car is warmed up and running, then it MAY indicate oil bypassing the rings or possibly a bad PCV valve.
If blue smoke comes out when you start it after sitting a short time, it MAY indicate oil leaking past the valve guides/seals.
Be advised though that in my opinion, a Justy with 90K miles may be close to the end of it's mechanical life, and may not be worth the repairs if needed.
Dave
oil was leaking *somewhere* but there was never a puddle under the car and it wasn't making blue smoke (burning oil.) I CAREFULLY went over the engine with a strong light with the engine running looking for wet/oily spots. I discovered that a gasket had a gap that was letting oil escape when under pressure. The gasket was vertical, on the side of the engine and the gap was on the top side. So, the oil didn't leak when the car was stopped. It might have splashed near the gap when the car was idling, but not enough to leak out. But, it must have really squirted when the car was driving. I cleaned the area with degreaser and pipe cleaners. (Brake parts cleaner evaporates away oil really well and leaves a nice dry surface.) I saturated a piece of string with gasket sealant. (RTV) I loosened the bolts just a bit and stuffed the gooey string into the gap. (not further in than the gasket, though...) Once the RTV set I tightened the bolts down on the string to squeeze it all together for good. It's been about a year and the leak hasn't recurred.
