Leaking Engine Heater or Freeze Plug Leak?
I have a 1992 Chevrolet Suburban with 100,000
miles on my 350 engine.Directly in front of my oil
filter mount is either a freeze plug or engine
heater installation. For three months various
people haven`t been able to explain why I had
engine coolant leaking from the hole in the bottom
of my steel fly wheel cover.
Today there is a fast drip from the item mentioned
above. As I see it either a freeze plug has rusted
thru or the engine heater assembly is leaking.
Are special tools needed to remove freeze plugs or
to install a new freeze plug.
Are engine heaters installed in freeze plug holes
or is there a special threaded hole for these
units. Does removal involve soaking this area with
rust solvent and then using a normal wrench for
removal.
I have installed things like new starter motors,
water pumps, fuel pumps, radiators and plugs but
have never worked on block heaters or freeze plugs.
Should I leave this to a good mechanic?
Would appreciate your thoughts.
Don.
removal.
Don.
don
