bmw reliability/maintenance?
Welcome to Town Hall.
You will probably find more BMW owners hanging out in some of our other conferences, rather than here in Maintenance and Repair. We have not had a whole lot of discussion here about issues with any BMW - perhaps that is a good sign (!), I don't really know.
If you haven't already, I suggest you use the Topic Search feature on the left side of this page for 3 Series and look for an active topic in the conference that seems most appropriate.
Note that a search for "3 Series" will return topics with both "3 Series" and "3-Series" in the title, but a search for "3-Series" will not find topics that contain "3 Series" -- got all of that? ;->
Good luck and again, welcome.
Pat
Pat
I think the car is a lemon, but BMW and the dealership essentially say I'm stuck with the car. BMW again??? NEVER.
Right now I have almost 70k miles on my 328i. The first 36k miles of service/maint were covered under warranty so it was free. After the free maint expired the only things I've had to do is regular oil changes (approx every 15k to 18k miles at $35 each if I do it myself or $70 at the dealer).
at 65k I had an inspection II service (major tune-up type service) it cost me $400 which included new spark plugs (not necessary till 100k miles but I had it done anyways) without the plugs it was $300. I also had the front brake pads and rotors replaced (worn out) which cost me $300. for a total of $600.
This past week it needed a new thermostat (known issue on cars built before 4/2000) which cost me $170.
Over all it has been the cheapest car (in terms of maint) I've owned.
Other car's I've owned in the past includes toyotas and hondas which required $400 tune-ups at 50k intervals (vs 60k for BMW at approx same price) and domestic cars like GM, ford and chryslers which required the same tune-up plus something major always goes wrong every 30k miles.
(i.e. need new transmission every 30k miles on chryslers, need new wheel bearings & transmission & power rack&pinion steering on GMs and new engines on fords).
If you do 17k a year then your first 2 years of maint is free. After that you would be looking at approx $250 a year in maint. ($70 year one oil change, $400 year two inspection etc)
'97 540i purchased 4/2000 for $30,900 w/ 100K ext warranty that transferred from previous owner. Car had 66,000 miles.
1. Level I service, rear brake job, rebalance tires, $700
2. defective rear electric window, defective thermostat, continuing tire balance problem(turns out 17" cross spoke alloy rim is slightly bent), coolant level float gauge is stuck in down position, valve cover gaskets oozing oil slightly, check engine light comes on(related to emissions on BMW's) Repaired under warranty for $50 deductible.
3. Check engine light came on again under hard acceleration two days later. Will have to go BACK to the same shop. Various buttons on climate/radio stick a little, but no big deal. Chrome trim around windows is somewhat tarnished, perhaps due to prior lack of wax. Might be able to polish it out, but I have to wait till I have time.
Overall, very reasonable in terms of out-of-pocket costs, but ONLY because we have a good warranty. The actual guts of the car work fine, it's just the little things that BMW can't seem to get right. The EASY things, actually.
We will probably sell it before the warranty expires at 100K miles. But we bought it cheap, so it'll work out ok. I just like having a car I can take on trips and not fret about what's gonna happen.
Fred.
I am looking forward to many miles with this car.
