Chevy Celebrity Stalling problems
I have a 3rd-owner 1988 Chevrolet Celebrity w/ the
2.8L V6 engine that intermittently stalls. It
usually happens at a stop, with A/C on. The car
will idle rough, then suddenly cut out. Sometimes,
there's no period of rough idling before the stall.
Steps taken so far: Previous owner replaced EGR
valve. 7,000 miles later, my mechanic did same (I
wasn't aware of earlier replacement at the time)
due to a diagnostic code. Problem seemed to clear
up for a short time, but could have been placebo
affect. In any event, returned and continues to
this day (about 10 months later). What else could
be causing this? I remember seeing on one forum
(perhaps on Cars.com) that others were having same
problem.
Thanks in advance.
problem.
Thanks in advance.
May be fan or something similar. Hope this helps.
Happened to a friend's '84 Celebrity... One quick solution is to pull the plug for the TCC solenoid, located on the transmission case close to the bellhousing. You'll lose lockup above 45 mph, so the engine will rev slightly higher on the highway, but if the car is mainly used for around town, it won't matter. Otherwise, you can replace the TCC solenoid, on later 80s trannys the solenoid replacement did not require extensive disassembly of the tranny (I think it's under a cover).
